Question about Admiral 24 in. DWUA651 Built-in Dishwasher
The water does not pump or drain out after the wash is done
Is the pump done
  • sk8kirks Feb 07, 2009
    water...less than an inch...left standing in the bottom of our dishwasher after the cleaning and drying cycles are over...the admiral customer assistence line was of NO use... tkk
  • Anonymous May 09, 2009
    WHAT IF...solution one doesn't solve the issue with "less than a inch of standing water left behind"?
    Genius:
  • 2,920 Answers
You have something stuck in the pump i think.maybe a sock or something. try looking at the the pump....its clear so you should be able to see if anything is stuck in the or use a wire hanger and get up in there and pull out whatever it is thats in there
Posted on Jan 08, 2009
My top loader drains a little water while washing and then fills up again.
all draining is done with the water pump
and that is working
could be faulty water level solenoid / valve
but I suspect washing machine timer out of sync /control board
Jun 28, 2016 | Washing Machines
My GE gfwh2400loww washer, the pump filter needs to be drained every 1 or 2 times a wash is done..otherwise water stays in, and when you drain it, it smells musty and horrible. I checked the manual,
You should not have to clean filter . Check your hose for clogs ,follow the hose all the way to where it drains into the sewer line. If your sewer line is very high up the pump may not be able to pump out all water efficiently. So some water will flow back down to the pump. If there is a clog up high, the clog will not allow draining. These pumps are strong ,but not that strong. Please let me know what you find. GOOD LUCK FRIEND.
Nov 17, 2014 | Washing Machines
My washing machine leaks alot of water from the drain trap while it is working or when it has just done a wash.
Thanks for the model number. The leakage is very likely from the drain hoses that are connected to the drain pump. For your model the drain pump is located at the bottom front behind the bottom plate. You will have to remove the screws holding the bottom front plate. Once you get this out you can access the drain pump and hoses. Either one of the two hoses (inlet from drum or outlet to laundry drain hose) could have burst or lost hose clamp. Need to fix this. Also check the laundry tub drains are clear and there is no back water into washing machine.
May 01, 2014 | Washing Machines
The washer will not complete the cycle. It will not drain and spin.
There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is slipping or broken.
1 Fill washer with water and wait for the timer to get to the drain mode.
2 Unplug the washer from the electric outlet.
3 Open the case, and disconnect the water hose from the outlet of the water pump.
4 If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
5 Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
6 Reassemble hose from step 3.
7 Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
8 Reassemble washing machine case...you're done...
Jun 16, 2011 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain water during wash cycle i have to do it manually i've checked for blockages but can't find any
Please follow the steps provided bellow :
Thanks for contacting Fixya.com
Aug 16, 2009 | Tricity Bendix AW1400W Front Load Washer
My hoover washing machine will not spin and drain water at end of cycle. It starts the wash cycle it turns around but it does not fast spin at the end and drain the rinse water.
hello
Thnx for contactin fixya.
after goin through your question i felt There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken.
plzz follow these steps..
  1. Fill washer with water and wait for the timer to get to the drain mode.
  2. Unplug the washer from the electric outlet.
  3. Open the case, and disconnect the water hose from the outlet of the water pump.
  4. If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  5. Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  6. Reassemble hose from step 3.
  7. Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  8. Reassemble washing machine case...you're done...
hope this will solve your problem.
for further queary plz do let us kno,we will b happy to help you.
all the best
regards
Jul 23, 2009 | Washing Machines
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
It doesn't drain after the wash cycle
can you hear the pump humming? you may have jammed pump or a blocked pump.
Oct 31, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dishwashers Logo
219 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Oloyede Monsuru
Melissa Martin
Melissa Martin
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
