Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Top Freezer Not Cooling...Fan Running...everything thawed :(
GE Profile Arctica...Top Freezer...2002.
  • dsbolger Jan 09, 2009
    Thanks...now the fridge isn't working either...control panel on back is showing signs of wear. :(
    Scholar:
  • 40 Answers
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Posted on Jan 08, 2009
GE Profile Arctica Model PSS25NGNA CC Hi, I noticed that water was leaking out of my water dispenser. Upon opening the freezer I noticed that everything was thawed out. The doors had been closed and t
you ended with the fan starts to run ? check the coils there should be a fan that blows across the coils sometimes the fan gets to dirty dusty clean that out and make sure that it works it must be running to keep the gases from over heating also clean the coils as will help big time
Oct 22, 2012 | Refrigerators
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
My 5 year old fridge/top freezer ge profile just stopped cooling, motor running but no cooling
First thing I need you to do is unplug pull away from wall and remove the cover over the compressor. Feel the top of the compressor and if too hot to hold your hand on the top leave the refrigerator unplugged until we can decide if this is the start components or another part like a fan not working all the time. I will send a manual and be available for assistance if you want, Thanks, Sea Breeze
Jan 24, 2010 | GE Profile Arctica Stainless Steel Top...
Food in the freezer on my side-by-side GE Profile Arctica (PSH25MSSA SV) is thawing. Temperature is higher than normal (melted ice cream, etc.) but returns to frozen after awhile. Has happened many times...
It's hard to understand how the refrigerator compartment would be okay, but the freezer is not. The evaporator coils are normally behind the freezer. The cooled air is moved from here to the freezer and refrigerator by the evaporator fan. Is this the fan you are saying is going on and off? Or the compressor fan underneath the refrigerator.
The necessary conditions for proper cooling are:
1. Compressor is running; 2. Compressor fan is running; and 3. Evaporator fan is running.
Oct 18, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator and freezer no longer cooling. seems
coolant has leaked out, leak some where in the lines.
Sep 13, 2009 | GE Profile Arctica Stainless Steel Top...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
Freezer Thawing
EITHER replace or re adjust the THERMOSTAT TIMER MODULE , HOPE IT HELPS AJ
Jun 13, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
489 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
