Question about Fujitsu fi-4120C Path-Through Scanner
Can't install Fujitsu fi-4120C
I was given this scanner along with a copy of the drivers.
I searched the web and found that I need to install the Twain and Isis drivers. I only had the Twain on the disk so I searched for Isis online and installed that.
But then I found out that I also needed ScandAll 21 and I am having trouble finding it. I did find a file at https://www.orbitfiles.com/download/id3516088605.html
But when I was not able to open it after downloading it.
To make things even more complicated, I read in an Amazon review of the scanner that I also need to install USB drivers. ???
After installing the Twain drivers I was able to see that Scanner Utility for Microsoft Windows had been installed, but according to the manual I downloaded, I should be able to see the scanner on a scanner list there. It isn't there.
Any help would be appreciated. I've lost a few nights already trying to solve this issue on my own to no avail.
Thanks for reading.
  • maggie176 Jan 08, 2009
    I can't believe it. I don't think 2 minutes had passed and you solved my problem. Thank you both!! Sorry, I forgot to mention that I have Windows XP.
    It turned out all I needed was to download the ScandAll file. Once I had that downloaded, I was able to see the scanner in the Utility program. I had searched all over the Fujitsu site and had not been able to find the ScandAll file. Thank you so very, very much for your help.
    Now I just need to spend some time figuring out how to use the scanner. LOL I scanned my first doc but the ScandAll screen is so foreign looking to me. It reminds me of those first PC fax programs. Most everything is dimmed and what appears to be the obivous choice is usually not available. Oh well. At least, I know that it works and I have to invest a little time getting accustomed to the program.
    Thanks again!!!!! I am so looking forward to getting rid of 6 boxes of dust collecting documents for a teeny-weeny flash drive. Yeeeehaw!
  • 32 Answers
If this device is connected via Parallel, you'll need to enable ECP mode for the parallel port in your BIOS. Consult your computer's users manual. If it IS hooked up with USB, and you have the drivers, are you running Windows XP? If so, you should be OK. When you plug th device in a Found New Hardware window should come up if the device isn't already installed. Point it in the direction of the drivers folder and it should pick it up. Who knows, maybe they gave it to you because it couldn't communicate?
On XP: go to Start-> Run and type in Devmgmt.msc and hit OK.
Do you see any question marks/exclamation marks in the window that comes up? If so, try right clicking on the item and Update Driver from the folder with the scanner's drivers. It might be one of those devices. If not, the unit may be busted.
Posted on Jan 08, 2009
  • 827 Answers
I think you have to download the twain toolkit from here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers/twain/v918149.html
Try that and let me know how you get on..
Chris (ziraffa)
Mac compatibility
Fujitsu fi-4120C is not compatible with Mac OS X
Feb 04, 2014 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-6140 Scanner: Error 8 (help?)
Hello Connor,
Error 8 could be displayed due to:
1. Faulty cable connecting Panel PCA & Control PCA. Check the cables, it might have been pinched somewhere or may be defective. You may cross check by replacing the same with another scanner.
2. Faulty Panel PCA. You may cross check by replacing the same with another scanner.
3. Faulty Control PCA. You may cross check by replacing the same with another scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jan 09, 2014 | Fujitsu fi-4120C Path-Through Scanner
My fi4120c scanner doesn't work with windows 8 - help?!
Hi Lorraine,
Fujitsu fi-4120c scanner has been discontinued and is not compatible with Windows 8. Please follow the link provided below for more information.
www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-4x20c.html
Thanks & regards,
ScanCare
Sep 23, 2013 | Fujitsu fi-4120C Path-Through Scanner
Is there a Windows 7 64bit driver for fujitsu FI-4120C scanner available?
Hey David, According to the fujitsu website, 4120C is NOT supported in windows 7 at all... :-(
Sorry!
Dec 23, 2010 | Computers & Internet
I have fujitsu 4120c and it doesnot work,it have error 8.can anybody help me
Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Thank you for contacting Fixya.
Regards,
TechSatya
tech.satya@gmail.com
Nov 13, 2010 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
DOWNLOAD DRIVERS
Preferably download from Fujitsu here:
Driver Vista :9.18.709
Driver XP :9.18.149
If you still cannot download from website above (reccomended) , alternate download here: download driver for Fujitsu fi-4120C Scanner
Oct 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Im having a problem installing fi-4120c
how do i install scanner in my computer (benq scanner 4300) please let me know
May 22, 2008 | Fujitsu Office Equipment & Supplies
Fujitsu fi-4120C Path-Through Scanner Logo
1,575 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
