Question about Kenmore Washing Machines
My Kenmore washing machine-model#110.27802690 will fill, stop,
But won't continue cycle, no matter which wash cycle it's set on.
    New Friend:
  • 88 Answers
Check your lid switch
Posted on Jan 08, 2009
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Washer will not stop filling no wash cycle.
You may not have to change the complete water valve. Just check if there is anything blocking your thin pressure hose at the bottom end, and see if the pipe is not kinked or has holes in it. When you blow thru the lower end you should hear a click in the switch above - denotes it is fine.
Apr 28, 2013 | Kenmore 24032\24036 Top Load Washer
I have a kenmore model 110.28922790. It will not stop filling with water. What would be the likely cause?
the water pressure/level fill switch under the control panel is defective,it uses water level/pressure per you setting on the control panel for wash load size to fill it to the set level,then start the washing cycle after it fills
Mar 23, 2011 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Will not run continuously!
Either you have a faulty module or timer switch the dial used to set the wash program. If for any reason it ha been turned in the wrong direction your machie can behave exactly as you describe. Hope this helps.
Jul 29, 2008 | Kenmore 24932 Top Load Washer
Washing Machines Logo
89 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
