Question about Panasonic KX-TG8231B Phone
No link to base
I have try all solutions but nothing
    Sergeant:
  • 431 Answers
Give more informations please
Posted on Jan 08, 2009
How do I fix my phone?
Try another handset usually portable phones can have 2 3 or 4 handsets in the kit one is unusual if the second handset works then the phone is faulty usually the internal antenna cord has become dislodged which stops it being able to send or receive via the base
Solution 1 remove the battery cover & battery the remove the screws that retain the back cover of the phone & look around around for loose or dislodged connections.
Solution 2 get a 2nd hand phone off ebay (same make and model)
sychronise it with the base & if that works toss the faulty one
Solution 3 theses are relatively cheap Good Guys in Sydney
had Philips & Unident 3 phones & bases for under $50 recently
Solution 4 Get someone like me to repair the phone but it is likely to cost more than a new one to repair it, Pick a solution 1, 2, 3, or 4
Jan 11, 2015 | Lands Phones
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
My base does not pump cleaning solution thru the device. I will run the entire process, & there will be clippings in the bottom of the slot where the razor sits. The solution container is full, but...
The pump in the cleaning maching is broken. Pumps are not available seperately. Your only option is to purchase a new cleaning /charging machine. You will find this item for model 7570 available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 06, 2011 | Braun Syncro 7570 Electric Shaver
My hand set states it is not connecting to the base, This is with-in 5 feet. It worked before, now nothing. whats up? I've tried to reset everything.Even let the battery go down then retried again and...
Hi, if you have tried the best solution which is resetting the handset and it still does not connect to base, entering a new or the old code won't make any change a solve the issue. Then you have to contact the technical department of the phone company to make a report....
Oct 03, 2010 | Office Equipment & Supplies
Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Jan 28, 2009 | Panasonic KX-TG2357 Cordless Phone
No link to base message
Possible other frequencies in a similar range as the 2.4GHz phones are interfering such as interference from other electrical appliances or Uverse TV. Move the handset and the base unit away from any other electrical appliances and try again. Make sure the base antennas are fully extended.
Jul 10, 2008 | Panasonic KX-TG2740 Cordless Phone
No link to base
put the phone in its base and then un unplug the phone for 5 seconds plug it back in and check for a dial tone.
Feb 20, 2008 | Lands Phones
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
Panasonic KX-TG8231B Phone Logo
77 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
