Question about Tools & Hardware - Others
Loose sanding belt
I have a Ryobi 4x36 Belt/Disc Sander, Model BD4600.
Even with a new belt, it slips or stops as soon as a piece of wood touches it. The yellow gear on the right changes the position of the belt, but does nothing to tighten it. I don't see any kind of adjustment to move the two rollers further apart to tighten the belt. There is a screw inside the lever mechanism that allows you to change the belt, but it doesn't seem to have any relationship to make the needed adjustment.
The solution?
    Scholar:
  • 58 Answers
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
3 Suggested Answers
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
SOURCE: Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Posted on Jul 11, 2009
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
My Hitachi Belt sander SB75 the sanding belt moves off rollers as soon as applied to work piece how do I stop this happening?
There is a belt adjustment know on the side of the sander. Turn the adjustment know back and forth while the sander is running until it centers itself.
Jan 01, 2011 | Hitachi 3 In X 21 In Belt Sander, 2 Speed,...
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
Jan 08, 2009 | Tools & Hardware - Others
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
Tools & Hardware - Others Logo
733 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
