Hitachi 50FX48B shuts off for no reason !!
We have a Hitachi 50FX48B where it shuts off for no reason. There are no red lights on the front or anything. We would wait for awhile then we can turn it back on, then it shuts down when it feels like it. We were told that it might be a resistor #51, if so, where can we purchase one and is there instructions on the web on where it is located and how to replace it?
  • dnpvisyak Jan 09, 2009
    Thank you for your guidance. We will be sure to take these steps accordingly. We appreciate your guidance and time set forth in conquering our problem
    Scholar:
  • 150 Answers
If it is shutting off, you can have many things shutting it off. Hitachis are riddled with protect circuits. Excessive current draw from many circuits could cause a shutdown. Best bet is to pull back off and watch green lights on power board, first light off is usually a suspect circuit that would be good to look at (assuming you have one that goes out immedieatley). Some have had flakey regulators also.
Since this is an older non HD set, I would suspect regulator and a large Sandblock current sense resistor mounted right next to it, part / Location #'s elude me at this moment, but they are on the deflection PCB close to where the ac goes into the board from the power cord and fuse/ chokes.
Posted on Jan 09, 2009
What does it mean when your hitachi big screan tv wont come back on and the red light in fron keeps flashing ?
It means that you are sending a high resolution or framerate HZ not supportd by the Hitachi.
Try to start from 1024 at 60 HZ and then you step up a level at the time.
until you can see at max supported resolution
May 28, 2014 | Computers & Internet
I Need a New Power Transformer for hitachi model 50fx48b projection tv.Where can I can I purchase Transformer.?
www.tvrepairworld.com should be able to get any part for your Hitachi. Just click the contact button on the right side of their homepage and indicate your model number and what youre needing
Aug 20, 2011 | Hitachi 50FX48B 50" Rear Projection...
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
Have a 50fx48b Hitachi TV and screen flickers and then goes to small wavy horizontal line. smack tv and it goes back to normal.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Convergence chips for 50fx48b?
STK 392-110s use 150s Mats Electronics 1-800-628-1118
Jan 25, 2010 | Hitachi 50FX48B 50" Rear Projection...
I have a hitachi 50inch 50fx48b for free and trying to fix it i can hear it turn on but theres no picture or sound and if i push the power button again u can hear it turn off any help would be very...
hitachi has leds on the power board that will light up with the different supplies to let you know which is not coming up. there are small yellow chemical fuses that look like a plain yellow/green resistor with no lines on it. you can check them with an ohm meter to find the blown one. sometimes E994 will blow on the 120v line and you'll find a little blue "gumdrop" cap with a burn mark in it that caused it. the cap is just to the right about 2 inches in front of the horizontal output transistor (big transistor (3 legs) on a large heatsink
Dec 08, 2008 | Televison & Video
Remote code
Try some of these codes:
0145, 0151, 0056, 0032, 0038
Mar 25, 2008 | Hitachi 50FX48B 50" Rear Projection...
Hitachi projection screen 98modle
bump...anybody? I am having trouble locating my convection boards that so many other people have replaced on other models to solve there problems.
Feb 05, 2008 | Hitachi 50FX48B 50" Rear Projection...
Hitachi big screen
1) Check F903
2) Pull chassis = solder any / all bad connections
Qualified technician recommended................T.
Dec 13, 2007 | Hitachi 50FX48B 50" Rear Projection...
On and off rear projection 50''
does the red light remain on on the front? Hitachis are notorious for bad relays.
Jul 18, 2007 | Hitachi 50FX48B 50" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
