My hitachi ld328700 lcd tv picture has gone faulty and looks like something you would need to wear 3d glasses in order to view, everything else is fine with it just the picture and colour look to be in 3d
    Champion:
  • 225 Answers
ALL LCD/Plasma televisions have adjustment for convergence, RGB drive, color saturation and a virtual host of other parameters than can be adjusted through the "technician's service menu".
Unfortunately, you are not supplied with the information to access that menu and you're limited to a "user's menu" which allows you to only adjust some of the basics, like volume, tone, color, tint and several more.
Methods of access vary from manufacturer to manufacturer. And the main reason that a consumer isn't given access to these menus is simply because they can totally screw up a set with just the push of a button, requiring hours to correct by a qualified technician.
Of course, most all of them have a factory default to recover most of the settings, but there's still a lot of finite settings that would have to be adjusted to get your TV looking right again.
Depending on the LCD manufacturer, it may be adjustable for your specific set, or you could have a problem with the LCD digital or driver modules. Even the LCD display itself could be failing.
Best bet is to call a QAUALIFIED technician and have it checked out. If you don't have an extended service plan from where you purchased the set, or if it's out of manufacturer's warranty, some of the repairs could be quite expensive. enough so that it may be worth looking into buying a replacement set.
Posted on Jan 08, 2009
The picture looks like it is in 3d
If your TV looks 3D or warped your convergence has gone out. You will need to call in a shop or get a DIY convergence repair kit from www.TvRepairKits.com to fix it.
Jan 17, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Color fade upper left hand corner, looks like I need 3d glasses on the edges of everything
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 13, 2011 | Hitachi 50UX58B 50" Rear Projection...
When i turn it on, it gets a blue looking shadow color and the letters and numbers look like you're watching a 3D picture without glasses
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Hitachi 60DX10B 60" Rear Projection...
3d look with little bending in bottom left corner of screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Hitachi 52LDX99B 52" Rear Projection...
Display looks like you need 3D glasses to view.
Sounds like a convergence problem. Especially since you said that the screen(picture)wasn`t linear anymore.
If the magic/touch focus function doesn`t clear the problem then your convergence modules may be faulty. They are used to align the three tubes (red/green/blue) deflection. If you feel handy with a soldering iron i could assist you in replacing them, otherwise you might need the help of a local repair tech. Hope this help. Good luck
Dec 01, 2009 | Televison & Video
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Hitachi ld328700 picture and colour gone faulty
there was another guy on here that had the same problem and he ended up throwing the tv away because it cost too much to repair, you migt call a repair man in and see what they quote you on yours
Jan 08, 2009 | 2000 Ford Focus
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
My Hitachi 43UWX10B television
Needs Convergence IC
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 03, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
