Question about Amana SXD524VW Side by Side Refrigerator
Samsung refrigerator modelrs21dpsm1/xeu power 230volts
Refrigerator is working but evaporator fan is not working
    Genius:
  • 2,920 Answers
You may want to go ahead and replace the fan and relay,,one or both are going to be bad
Posted on Jan 08, 2009
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
None of the evaporator fans are working. Could this be a problem with the main board or the fans themselves?
there is usually only 1 evaporator fan? or do u mean the condensor fan as well? u can check both with a meter for ohms r u saying the fridge still works but no fan operation?
Apr 20, 2015 | Samsung RF4267HARS Stainless Steel French...
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
How to check fan in samsung srs585hdis
Not really a good way to explain how to get to the fans but looking at the=> SRS585HDIS Parts Diagram may help you see what is in the way. You also can contact Big Warehouse Spares. Parts for your model HERE=> SAMSUNG Refrigerator SRS585HDIS (RS21HDUPN1/XSA) Parts If this refrigerator is like most dual evaporator refrigerators made by Samsung the fan will not be the problem. The problem is a design flaw that causes ice buildup on the fridge side evaporator. You can clean the defrost drain and manually defrost the evaporator with a hair drier.. That fix should last a couple months unless there is a door seal problem causing excessive moisture buildup on the refrigerator side evaporator. I am here should you have any questions, Thanks John Tripp Appliance 911
May 16, 2014 | Samsung Refrigerators
I have a samsung twin cooling fridge model: RS21NCSV power: 230V/50Hz model code:RS21NCSV1/XEU [A] temperature is playing up!! Freezer is working no problem. The fridge is getting cold but not cold enough...
You almost certainly have a problem with either defrosting or evaporator fan motor. Please verify your model number so I can pull up your unit to provide troubleshooting information. Thank you
Mar 26, 2013 | Refrigerators
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
Hi i have a RSA1WTMH1/XEU fridge freezer side by side, it just stopped working on both freezer and fridge the fans are still going theres no ice build up on fans coils are clean. I did a reset and still...
Sounds as if you may have had a lightning strike in the area last night maybe, and the power to the house waqs not just interrupted, but was actually giving you low voltage! Enough voltage to turn the fans but not enough to run the refridgerant compressor. Very common. This is why they say to unplug your fridge when it is stormy or lightning outside. Low voltage power surges will do that. Best to have an expert or electrician come to see what the issue really is! Good luck with it!
Jun 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
