Question about Kenmore Oasis HE 27082 Top Load Washer
Multiple Errors & unable to turn off
Get the F1, LD and now the F6 errors. Did the rinse & spin and wouldn't finish or turn off. Also happened with the F6 error. Any solutions other than all repairman?
    New Friend:
  • 88 Answers
You probably have something in your pump. if the water didn't drain best bet is to check pump.
Posted on Jan 08, 2009
Calls error code at end of first rinse
Hi just read your posting.Error 136 means you have''Motor Stall " fault. Now just a couple of questions, has your machine been noisy on spin?does the machine leak water?Please reply with answers and I can help you rectify this fault.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting dc error code in rinse cycle, 13 min. before being done Have un-pluged and still getting code. Maytag FAV6800 LED washer, 5 years old.
Hello rdberg,
See this post Clutch Fix it has helped a few owners with the dC and uC unbalance errors with the FAV6800A and FAV9800A machines. You have a very common problem with a Clutch malfunction. The first part of the post has to do with the nuts and bolts of disassembly and Clutch maintenance or replacement of the Clutch Pulley.
In the last part of the post I go into just how to check the One-Way Rollers clutches to verify that are locking up. If they don’t this results in tumbler movement on Wash Basket spin up and the unbalance errors. If you are handy and have some basic hand tools you can get your machine back in service at low cost.
Post back if you have questions…..Rich
Mar 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Whirlpool Cabrio Top Loading washer model WTW6400SW1. During the past month, I have been seeing the "LD" error code ("slow to drain") but not the "F1" code during middle of the wash cycle before...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LD error
consult your manual for the answer
Jun 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
Call and complain a lot. There is a class action lawsuit agaisnt whirlpool (whirlpool made the oasis) for this problem. It is a faulty control board. Some people have gotten sears to pay for the repair. Try that. good luck!
Nov 19, 2008 | Washing Machines
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Nov 04, 2007 | Fisher and Paykel IWL12 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
176 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
