Question about Maytag MBV1976AAP Beverage Cooler
Skybox wont dispense
I checked low product switches main board has both led lit fan not working
  • 700 Answers
Look for ice blocking the door on the unit and causing it not to fully open , good luck
Posted on Jan 08, 2009
Where is the fan located?
The fan is located behind the bin dispenser assembly. It is a low voltage fan, and runs as soon as the SkyBox is plugged in. The thermostat controls only the compressor.
Jul 17, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox cools but nothing else works, no LED lights, no dispensing
If none of the LEDs are working, sounds like the transformer has went bad. First look at the board for a fuse to see if its blown, if so replace, see what happens next. To check and change the transformer you need a volt/ohm meter. If you do, and are feeling ambitious, I'll need some info off the schematic or the transformer itself, and I will walk you through it.
Dec 28, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
What are the two red led lights on a skybox circuit board for? Mine are lit up and the unit won't cool. Is that an indication of what is wrong? If so, any idea what it is?
The red lights on the board indicate it is working properly. The purpose of the board is to control the dispensing of the beverages, and has nothing to do with the cooling process. You have a cold control (thermostat) inside the refrigerated area. The cold control is like a switch that sends 120vac to the compressor when cooling is needed. The failure of the unit to cool would be either a bad cold control, compressor, or compressor start relay. Testing of live electrical circuits should be left to a qualified service technician.
Oct 05, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Need a part dispensing moter shot
The motor was never offered as an individual replacement part. The entire dispenser assembly was the only way the motor was availabler. Marcone Appliance Parts (1-800-482-6022) shows a single dispenser (11001187) left in their national inventory in the Jacksonville, FL location.
Mar 15, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox not dispensing :(
What your email i can send you the manual on it
Jul 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Low product light stays on
You can go to and purchase a new switch for the low product. It mounts on the back of the dispensing rack, item number is 18 on the assembly diagram. It is also possible that the existing switch has become unplugged from the board by ice buildup.
Jan 25, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Mar 01, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag MBV1976AAP Beverage Cooler Logo
115 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
