Question about Nintendo Wii Console
Plugged US purchased Wii into Europe outlet with an adapter and n
I plugged my Wii, which I bought in the US, into a outlet in Sweden.    I
thought I was using an outlet conveter, but I guess I plugged the Wii into an
adapter which says input AC 100V-250V.  Aparently there is already an adapter
on the Wii cord which says AC 120V. Anyway, when I plugged it in it was fine
and then the power went off after about 5 seconds.  My TV which was also
plugged into the same outlet lost it's power, but it still works because it was
bought in Sweden and doesn't need an outlet converter.  Can someone please tell
me what is wrong.  Did I blow a fuse?  Is the fuse in the Adapter on the cord
or is it in the Wii?  Is it something more serious like ruining the Wii itself?
 Please let me know what is wrong and what I can do to fix it.  If it's just a
fuse, how do I buy that and change it?  Can I buy a new cord that will plug
into European Outlets and still work with this Wii which was bought in America?
Thanks for all your help
  • prettyboy_ni
    prettyboy_ni Feb 04, 2012
    Hye ndsoccer7, i face the same problem. How do u fix it?
  • prettyboy_ni
    Hye ndsoccer7, i have the same problem. How do u fix it?
I am wondering how I can get the WII fixed. My nephew received one for Christmas two years ago when living in Germany. Is there anyway to fix it? Would appreciate any help. Thanks. Chris ...cquednau@charter.net
Posted on Nov 13, 2012
  • 32 Answers
You would need an adapter that not only runs at 120 or 240 volts, but also one that OUTPUTS 120v. The Wii may have some kind of protection in it if you're lucky (most people don't hook up US Wii's to 240v). But if not, you've killed your Wii. Check the adapter, if it has a fuse that's removable you should see a (usually) circular cap kind of thing on the brick you can unscrew and pull the fuse out.
As for what you would need to purchase, it would be something like this: http://www.amazon.co.uk/Step-down-voltage-converter-240V/dp/B000L99ZJ2 would work perfectly. The Wii only draws at maximum 30watts and this unit does 100. Your TV on the other hand would need a higher wattage unit.
Posted on Jan 08, 2009
  • prettyboy_ni
    Hye justin, how do i fix my wii?
Wii no longer turns on! no power??
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. The AC adapter must remain unplugged at both ends for a full two minutes.
  1. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  1. Check the AC Adapter for the following:
  • Make sure that the word "Wii" and the model number "RVL-002 (USA)" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
  • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If the AC Adapter shows signs of physical damage and needs to be replaced, a replacement can be purchased from Nintendo's online store.
  1. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
Aug 16, 2012 | Nintendo Wii Console
I have no power to my wii what could be wrong
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
    The AC adapter must remain unplugged at both ends for a full 2 minutes.
    Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports.
    While you're waiting, check the AC Adapter for the following:
    Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter.
    After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
    If resetting the AC Adapter did not fix your power issues:
    Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices.
    Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage.
    Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    Check the vents on the back and side of the Wii for dust build up. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in.
    Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
    Once plugged in, check the power light on the Power button to see if the system is receiving power.
    If the power is still continually shutting off regularly, contact Wii support.
Apr 08, 2011 | Nintendo Wii Console
No power plugged in outlet working plugged into back no lights comming on
Either 1) your Wii's power adapter is broken, or 2) your Wii is broken. If you have a friend who has a Wii, you could try borrowing their power adapter and seeing if the Wii turns on. If it does, then you know your power adapter was broken, and you can purchase a replacement.Otherwise, you're going to have to look into repairing the Wii. If you device is under warranty, Nintendo will repair it for you.
Consult Nintendo's troubleshooting guide here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/index.jsp
Good luck.
Feb 28, 2011 | Nintendo Wii Console
Console won't turn on
Hi there, Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
4. While you're waiting, check the AC Adapter for the following:
? Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
? Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power issues, please continue reading:
? Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
? Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
? Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
? Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
? Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
? Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
? Once plugged in, check the power light on the Power button to see if the system is receiving power.
If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Take care.
Sep 27, 2010 | Nintendo Wii Console
Does the wii have a fuse? Unfortunately my daughter plugged the 110V device in 240 outlet & on-ned it.
Hi. I am pretty much sure that your Wii has no prblem. Just purchase a new adapter and werything will work fine. I suggest you buy international adapter (110-240v)
Sep 13, 2010 | Nintendo Wii Console
Wii will not turn on, all cables are connected and plugged in
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power.
If that didn't help , then I recommend you to replace your Wii with new one if you still have the guarantee !
good luck .
rate please !
Mar 23, 2010 | Nintendo Wii Console
Wii won't turn on
Hello :
good luck .
rate please !
Wii plugged to 220v oulet. Burning plastic smell on adapter only.
Probably the adapter if you saw it burning from the adapter. I think you can replace an adapter from a store. Hope that helps.
Jan 20, 2010 | Nintendo Wii Console
My wii will not turn on, i have everything plugged in the rite spots, it was working just fine the other day, this is the second time this happend . do u know why?
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
See the following webpage @ Nintendo for more information:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Oct 21, 2009 | Nintendo Wii Console
What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Oct 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
393 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
