Question about Canon DR 2080C Path-Through Scanner
Canon 2080C scanner software causing monitor issues
Every time I install the "capture perfect" software for my Canon 2080C scanner an hour later the monitor starts getting wavy lines through it. I have changed the monitor. Same results. I have tried the 'bad' monitor on another computer and it's fine. I have connected the scanner to a different computer with the same software. The wavy lines appear again. Any info or help is appreciated.
  • Sara Barrett May 31, 2007
    I have tried your suggestions before I posted to this site. I did not find any info on Canons web site.
    Genius:
  • 2,985 Answers
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
Posted on May 31, 2007
SOURCE:
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
Canon DR-1210C scanner does not work with Capture Perfect software
you can download and Install Twain driver for this model and you can scan from Any Image Editor like photoshop and Acrobat PDF editor
download link http://www3.canon-asia.com/downloads/drivers/dr/DR1210C/DR-1210C%20Driver1.1.zip
Feb 06, 2013 | Canon Office Equipment & Supplies
How can i get capture perfect software for my canon dr 2080c?
Go to their official webpage, and try to find software... or just download this Driver Update Software for XP Vista 7 8 and make the update. I hope I have helped. Have a nice day
Paul
Jan 18, 2011 | Canon DR 2080C Path-Through Scanner
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
"warming up" all the time
If you go to the Canon Support site for this scanner they have a firmware upgrade that seems to specifically address this problem:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2204&modelid=13057
May 02, 2009 | Canon DR-1210C Scanner
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Feb 23, 2009 | Canon DR-9080C Path-Through Scanner
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Missing the disc
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=7181
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here: http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Capture/Capture-Perfect.shtml
Oct 02, 2008 | Canon DR 2080C Path-Through Scanner
Incompatible with Vista 64-bit
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Aug 26, 2008 | Canon DR 2080C Path-Through Scanner
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
142 people viewed this question
Clive
Clive
old marine
old marine
