Heat Pump hums, clicks and does not come on sometimes
Lennox Heat Pump- M/N 12hpbz4-4p Excuse me for waiting so long to find solution for problem but I tend to procrastinate. This problem has gone on for a year or so. Cold weather now and the heat pump sometimes makes a loud click when turning on and off. Also, when the air handler comes on inside, the heat pump does not always come on. Instead it makes a loud hum but fan does not switch on.Eventually it does. Twice I went out and shook it and fan came on but i am not sure if it was going to come on anyway and that was just a coincedence. I called Lennox today and to see if I could talk to a tech but could not get past receptionist. She told me that outside unit should come on at same time as inside air handler. Is this true?
Had it serviced last week. Repairman took out indoor coil (which was filthy) and cleaned it outside with solution. Also cleaned outside coils with solution. Heat pump would not make noise of course and fan came on with him here but it was also a warm day if that matters. He turned it on and off a few times. Said he thought it was going to be the contacts, but he said if it was then they would of made noise while he was here and they usually go out for good. He is hinting that it might be motor but when it runs, it sounds great and he did not say anything like it sounded like it was going bad. As mentioned the clicking noise and fan not working while it hums happens often but not all the time. Not sure if I am imagining that it happens more in colder and warmer weather or just happens that I am outside and happen to hear it.
  • 5 more comments
  • gulfbeach47 Jan 08, 2009
    I am guessing that the start capasitor is what is stopping the fan from coming on?
    Contactor chattering? Did you mean the contractor (technician) or is that a part? If it is the part, would that be what's making the loud clcik at times when heat pump come on and shuts off?
    Also, was the lady correct at Lennox when she said outside unit should come on at same time as indoor handler?
    The click or metal ping sound happens when unit comes on and shuts off. When there is a hum, the motor or something in there is making a loud hum but fan blades are not turning. Then there is a sound when fan comes on. Is it just a coincidence that fan comes on when I shake the unit? I can feel the heat coming up from above fans when it is not running. Will the motor burn out when it is making this hum and fan not moving? Can the tech test the start capasitor or do you just switch it out and hope that is the problem?
    oops...not sure if last post went through. I pointed mouse over where i was printing and everything vanished. For some reason you cannot copy/paste here.
    I guess my other reply went into cyberspace. I hear a ping or metal sounding click when fan comes on and when it shuts off intermittently. Not all the time. Seems like it happens more in colder weather but not 100% sure about that. Happens in heat of summer too. Fan is facing up, so when my air handler comes on and I hear the hum outside, I go out and look and if it is still humming, then the fan is not turning. But at the same time there is noise coming from in the heat pump (maybe the motor humming?) As I look down I feel heat and see steam coming up from unit. I don't feel any heat coming from sides of unit that I have noticed. Don't know about air pressure leaking out sound. It would have to be loud for me to notice because of some hearing loss. Defrost mode? If it has not been running long would it be going into defrost mode? It has been running for a few hours tonight and no hums or click that I have noticed so far. If fan is not turning and unit is humming can motor burn up unless it is defrost mode as you suggest? Is there directions on how to change out a start capacitor some where if that is the problem. And is it hard to get to...especially for someone that has no experience? How much does a start capacitor cost usually?
    You wrote> "some brands of units have a delay in the outside units board to stop it from starting at the exact same time as the air handler." Would the brand with the delay sometimes let heat pump start at same time and other times, not let it start for awhile and be humming during this time? Ok. so all tonight it has not made the metal click sound and seems to be running fine, but it will happen again. So, would you be leaning towards replacing start capacitor or ? I forgot to ask last reply is here a way ot test the start capacitor? Kind of unsure what to do about the problem. I hate for the motor to burn up. I am not sure if me technician knew what he was doing. He did not offer any advice. Just $165.00 for cleaning and looking for problem. last time I got the cleaning for $75.00 but it was a friend of a friend.
  • Anonymous Jan 25, 2009
    Steam comes out of the outside unit, and sometimes the fan and green light stays on for a while on the thermostat inside, is this normal?
  • dwkcool May 11, 2010
    sounds like you might have a start capasitor going bad and a contactor chattering
  • 96 Answers
Yes the start capasitor starts the fan motor and the contactor pulls together when the t-stat tells it to start and it has a spring in it that gets week , some brands of units have a delay in the outside units board to stop it from starting at the exact same time as the airhandler
Posted on Jan 08, 2009
  • 2 more comments
  • dwkcool Jan 08, 2009
    is this happening when it is very cold out and do you feel the heat from down by the fan area, plus when the fan kicks on does the noise you hear sound like air presure leaking out
    if you got my last posted and all of that is true ,the unit is just going into defrost mode and there is nothing wrong with it
    if it"s not in defrost mode yes it can burn the motor up and the capasitor can hold anywhere from 370 volts to 440 volts so please be careful around it and they are all different prices
  • dwkcool Jan 09, 2009
    yes I would put a start capasitor on an maybe a hard start kit but for sure a capasitor
I have a problem with getting my heat pump to come on. Sometimes it will be just fine and other times the green light on the thermostat will just keep blinking...and then at times it will finally come on and about 30secs later shut off without a temp change...Could this be my thermostat going bad??
Posted on Dec 13, 2009
    President:
  • 2,692 Answers
The pump (compressor) runs in the same direction all of the time. If it has a clicking sound and hum then the motor is not starting. It is then either the starter relay or more likely a start capasitor,if the unit has one .  I hope I have explained well. I also concure that the compreassor shoudl be running when the air handler is on .
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Why is it whining and humming?
Sometimes a louver on the squirrel cage comes loose maybe from taking it apart...hand test every louver. You may find that you need a new one.
Jun 29, 2012 | Emerson Lennox Ducane Armstrong Furnace...
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
4,992 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
