Question about Sony MDR-NC20 Consumer Headphones
Sony mdr nc20 low volume on one channel
Volume on one channel on my Sony mdr nc20 is lower than the other. Difference is very significant. Both channels do get sound but I have to balance far to the left to get similar volume. Replaced battery. Connectors look good.
  • Anonymous Mar 19, 2009
    Identical problem with mine.
2 Suggested Answers
supernova278
  • 1932 Answers
SOURCE: do all MDR IF5000 Sony wireless headphones have
Yes they have both volume and Balance control on it
Here is the Image
supernova278.jpg Thank you
Posted on Nov 08, 2010
SOURCE: Describe your Sony MDR-NC20 replacement cable
Overpriced, yes, but available:
https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=67362&searchOperation=modelSearch&searchText=MDRNC20
Posted on Nov 15, 2010
When i put them in the tv they work for like a sec and they stop working
Turn volume on tv all the way up and make sure your batteries are charged. Also test on a PC or laptop if u can.
Jan 15, 2013 | Sony MDR-RF970RK Headphones
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
Sony MDR-XB700 broken left ear
You could try to use a player with a stereo balance and adjust that, but in reality you need new headphones. Sonys have very comfortable and flexible cabling but the downside is that they wear out easily.
Mar 13, 2010 | Sony Audio Players & Recorders
Describe your Sony MDR-NC20 replacement cable Problem: have lost cable that connects to headphones--strange, unique jack. I need an adaptor to mini jack. Where to find?
Dec 29, 2009 | Sony MDR-NC20 Consumer Headphones
Sony mdr v150 wiring plug adaptor 4 wires green,
The green wires go to the left channel (Plug tip). The red wires go to the right channel (plug ring 2 band from tip) and the brass wires go to the ground (sleeve plug base).
May 05, 2009 | Sony MDR-V150 Professional Headphones
Sound cut off every 10 minutes
Turned up volume on receiver and turned down volume on the headset......no more problem. Thanks to the person who posted that solution on the web site.
Jan 11, 2009 | Sony MDR-RF970RK Headphones
Can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
May 27, 2008 | Sony MDR-RF970RK Headphones
The sound just stops dead
I have the exact same problem. Try to crank up the volume from your stereo/receiver and lower the volume in the headphones. I think that the headphones goes into standby mode if the volume is to low. Works for me (for two days, so its not really a fact yet ;-) )
Feb 24, 2008 | Sony MDR-RF970RK Headphones
Sony MDR-NC20 Consumer Headphones Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
