Question about Refrigerators
Cant get filter out of kenmore elite 106.58173703
It describes in manual to push the eject button and the filter should pop out but it doesnt and the eject button is very hard to push in. Also, the water dispenser tubing at the bottom of the freezer door does not seem to want to stay in its connectiing tube located behind the grille. And....Ive got 2 extra pieces 1 black flexible knob as well as a hard grey knob!!?? It doesnt say in the manual what these are for!
SOURCE: No water thru door
I am having the same problem with me GE side by side. I check my gasket and I don't have any screws so I assume that I have a "foamed in place" doors. I did notice when took the front of my ice / water dispensor off the circuit board has a connection named "heater". Is there any way to check heater and if it is bad how and where do you replace it. Thanks.
Posted on Dec 28, 2007
dcp2
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
  • 3 Answers
OK guys, GE does have a solution to this problem and it's EXPENSIVE. I goofed and called GE repair. $263 later it was fixed. Here's what I've done to villify them:
General Electric Company March 31, 2008
3135 Easton Turnpike
Fairfield, CT 06828-0001 Attn: J. Immelt Dear sir or madam, or whoever opens this because I know Jeff Immelt won't be the actual person to open it. This has already been sent to GE Corporation Appliance Park 6, Room 129 Louisville, KY. 40224 so don't send it to them. Send it to someone who may actually do something about this problem. I have a GE refrigerator, Model GSS25WGPAWW, S# AF 217252 which has had a continuing problem for several years. My first error was in not reporting this sooner. My home is in a gated community in which the developer used GE appliances exclusively. What I have determined now (after I paid for the repair) is that many residents have had the exact same problem: the in-door water dispenser freezes solid. The second mistake I made was calling GE repair to fix the problem. I was charged a total of $ 263.15 for the repair; $ 63.30 for the part, a flat rate of $79.95 for the repairman to show up and then $105.00 labor cost plus tax. Our community has an Internet based communications system ( Googlelist) and I posted the following message there. . My fellow residents responded that GE did fix many of the same problems at no charge after they call GE Customer Care rather than GE repair. Several others have paid for the repair. I then reported this to your sales http://www.geappliances.com/service_and_support/contact/form_service.htm) department up until the 25th of March , I have received no reply. ____________________________________________________________________________ TO:http://www.geappliances.com/service_and_support/contact/form_service.htm Just thought you'd like to know: I live in a gated community with over 1400 residents and they all got the following message: Posted on Googlelist-at Herons Glen So my water line to the in-door dispenser kept freezing up. I'd have to turn the fridge off and open the freezer door for up to 5 hours for it to melt. Then 3 or 4 days later it would freeze again. So the GE repair guy came and installed a $63 part in about 20 minutes. It was a heat tape applied inside the dispenser cover. Now for the fun part: $79 just to show up and then $105 "labor" ??? That's about $315 per hour - my kind of job. Oh yea, another $14.90 in taxes. Once I had the part number, I found the part on-line for $42. Forget about it really being a manufacturing defect that should be covered by warrantee. GE does not care! They advertise how "energy conscious" they are and then solve a defect with a heat tape that adds heat to an appliance that's supposed to be cold! Go figure! If this offends any ex-GE employees....GOOD _____________________________________________________________________________________ When I subsequently called GE customer Care on March 25th I was told "we have no recalls on that model and there is nothing we can do". I've gone on-line and searched for "GE water dispenser" problems and, WOW, you've got lots of problems. On March 26 I got a reply from From: answerctr@exchange.appl.ge.com They gave me a Tracking Number and another phone number to call 1-888-348-7563. I called that number on 3-27-08 and got the same answer: "we have no recalls on that model, have a nice day". My question is: Will GE do something about this? I have $ 263.15 out of pocket cost, a copy of the repair bill is enclosed, for what appears to be a design flaw and that flaw has been repaired for others "at no cost". Sincerely, Tom Morookian 20729 Mystic Way No. Ft. Myers, FL 33917 239-731-3452 Tommorookian@aol.com encl: (1)
The real problem is that the water line is supposed to be installed against the front panel of the freezer door. During assembly they don't do this so some of the lines are against the inside edge of the door, they then "foam" the door and they freeze. The heat tape does fix the problem and you can do it yourself. I'm "GEsucks" for a real good reason. I've posted this on several web-sites and I'm looking for a lawyer to file a class action suit!
Posted on Apr 21, 2008
  • 6 Answers
SOURCE: Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Posted on Aug 07, 2008
  • 1122 Answers
SOURCE: Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Posted on Mar 02, 2009
Reset Change Air Filter Light
TRY TO UNPLUG IT FOR ABOUT 10 MINUTES AND RETRY WHILE HOLDING THE BUTTON.
Jun 18, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I can't remove the old filter to replace it. You're supposed to push the button in and it would pop out, but it won't go in. 56166501 is model.
If its been some time since you last changed the filter then you may need to pull the filter holder while holding the eject button. Don't twist the cap on the holder, just pull.
If you can't get a grip on it and the eject button still doesn't work then remove the base grille by openeing both doors and pushing the top and pulling the bottom to give you better access to the eject button and filter holder.
Jun 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
When i push the eject button the cd doesnt come out...so how do i get the cd out??
There should be a small pin hole near the eject button. push a paperclip far into this hole and the try will pop out.
Aug 15, 2010 | Computers & Internet
I bought a new water filter for our kenmore elite refri. and i cant the filter to stay in, it keeps popping out.
Check the oring seal for damage. If it is not in place - the filter will not fit properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2010 | Kenmore Elite 44723SS Commercial...
My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Dec 08, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I can't get the memory card to stay in the camera. The eject buttom pushes it out.
You haven't said which KM model you have. But on most of them one push on the eject button makes the eject button pop out in order to be ready to use on the second press which ejects the memory card. After pressing the button all the way in to eject the card, the button should latch back into the "parked" postion.
Before re-inserting the memory card make sure that the eject button is already in the parked position. If it isn't then you'll get the problem which you describe.
Oct 12, 2009 | Konica Minolta Cameras
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Light flashes remove filter and clean
did try kenmore website
sears has a great place for trouble shooting
Feb 06, 2009 | Kenmore KCM12 Coffee Maker
Ejecting the water filter
rigth next to the filter itself "on hte toe grill" should be a spot marked "PUSH"
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
