Question about Canon PowerShot S400 / IXUS 400 Digital Camera
LCD Monitor blurred
The LCD Monitor has a shiny pink streak almost the width of the screen when on Record Mode but disappears when it is in playback mode. I can see clearly through the small viewfinder on the top of the camera and the pictures I take are not affected. What is wrong with the Monitor?
  • icecold00 Feb 02, 2009
    There is blur on LCD display when record mode is active only.But camera can take photos or record videos without blur.Also I can see photos or videos clearly when playback mode is active.Is it because of a magnetic field or something?
    I noticed that there is blur on recorded videos!
Please check out http://www.fixya.com/support/t1568206-red_streaks_across_screen
Posted on Feb 14, 2009
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
When i start my PC on the screen where there is pink background color their I see all pink color replaced with small - small red pixels .... I have adjust and done all possible method on Menu(Setting)...
Pink and pink streaks are a sign that the CCFL lamp is about to fail. The CCFL lamp provides the backlight to the monitor.
To confirm that the monitor is faulty and not the video card, connect a different monitor to your computer.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
May 14, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Picture gets blurred and then disappears.
christian204, Your unit may be 5 -6 years old, and may have developed a problem with it's internal "switch-mode-power-supply" and will need good CCFL backlit lcd monitor tech to repair it. When strange and wierd things start to occur on lcd screens the first place to look would be the SMPS. 12fixlouie
May 11, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Playback problem
do u see these streaks in lcd as well during rec or just in output
and also first try cleaning the head with head cleaning cassette if it helps otherwise ur problem is this see the link just call JVC for free repairs for CCD Sensors u get streaks blackouts and dsicolored picture when CCD goes Bad no problem it is a known problem just call them in ur region they will arrange for free repairs and pls rate me FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Apr 11, 2009 | JVC GRD250 MiniDV Digital Camcorder
Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
Feb 06, 2009 | Canon ZR60 Mini DV Digital Camcorder
Blurred pink LCD picture
This is a manufacturing defect. Send the camera to canon repairing shop.The will do it free of cost.
I had the same problem,
Jul 14, 2008 | Canon PowerShot A95 Digital Camera
Screen goes pink
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 27, 2008 | Acer Aspire 5102WLMi Notebook
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
171 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
