Question about Kenmore 63942 Dryer
How do i removed the dryer motor
How do i remove the dryer motor
  • onthethejob1
    onthethejob1 May 11, 2010
    please send model number
How do i remove the drive motor for this dryer?
Posted on Jan 15, 2009
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
Why doesn't the dryer stay running when I let go of the start switch?
Hi, There is only one reason I can see the dryer stops after you let off on the start switch is the motor because GE motors has start switches either built inside the motor which is non removable or built outside the motor which can be replaced .
Its called a motor start switch and the way to locate it is to remove the front panel on the dryer and remove the drum and belt and then write down the motor model number and look at all the wires that go into the motor which is your motor start switch that is held in by two screws but before you remove it don't forget to copy the wire down on piece of paper of how you remove them .
If you don't see a black switch to the motor then its built in and the motor needs to be replaced.
Oct 23, 2014 | GE DWSR483EBWW Electric Dryer
How do I get the old motor off to replace it if it is stuck
Remove the front blower cover assembly. Remove the round retaining clip on center of blower wheel. Pull blower wheel off motor shaft. Remove belt from motor pully. Pull out dryer drum. Remove clips holding motor to base frame. Remove motor assy. Easy peezy. Reassemble in the opposite manner.
Jun 21, 2014 | Whirlpool LEN2000PW Dryer
How do i replace the motor belts on GE Dryer model DPSR475E0WW? The squeeking is unbearable.
Instructions Things You'll Need:
  • Phillips screwdriver
  1. Step 1 Unplug the dryer and open the dryer door.
  2. Step 2 Unscrew the screws under the top lip, where the dryer's door closes, with your screwdriver. Once these screws are removed, lift the top off of the dryer. On older models, the entire top will hinge upward out of the way, and on models made after 1997, half the top will pull off.
  3. Step 3 Remove the screws on the inside-top corners of the front panel so the front panel of the dryer can be removed and set aside. On models made before 1997, the front panel should be carefully set to the right side; on newer models, the panel should be set to the left side of the machine. Be careful not to damage the door-control wires.
  4. Step 4 Locate two screws approximately 6 inches off the floor on each side and remove them, allowing you to push the sides of the dryer slightly apart so the drum can be removed. Pull the drum slightly toward you and reach around to remove the dryer belt from the motor pulley. If the belt is broken, this step should not be necessary. Once the belt has been removed from the motor pulley, the drum should pull up slightly and out of the dryer toward you.
  5. Step 5 Remove the old dryer belt and put the new one in place, with the ribs of the belt facing the drum. The slack part of the belt should be placed near the motor. Reverse the previous directions to replace the drum, replace the screws that hold the sides in place, replace the front and replace the top.
  6. Step 6 Pull the dryer out from the wall and remove the four screws holding in the panel near the bottom of the back of the dryer. You will see the motor, the drum and the belt you just set in place. Loop the belt around the motor pulley and the idler pulley, and turn the drum by hand to make sure that the belt is straight and will stay in place. Screw the panel back on and push the dryer back into place against the wall.
May 15, 2010 | Dryers
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
How to Replace Dryer Motor
make sure its unplugged,pull over the pulley to losen belt,unplug electrical connector from motor,take any bolts and nuts lose.remove motor.install new motor in opposite of removal.
May 15, 2009 | Frigidaire Dryers
Dryer not turning. belt is good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 17, 2008 | Whirlpool Dryers
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Kenmore 63942 Dryer Logo
114 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
