Question about Insignia IS-LCDTV32 32 in. Television
I have a Polaroid tv. My cable company came out today and updated me w/ digital tv and dvr. Things were fine when the tech was here and afterwards I watched a dvd and when I switched the input back to the cable, it keeps saying "no signal." I have tried all the differnet inputs and changed the channels and still no luck.
    Problem Solver:
  • 12 Answers
Check the back of your TV. Your cable is probably hooked into a Composite or HDMI input, I doubt they would install it directly to the TV's tuner, these days thats reserved for local antenna's.
Posted on Jan 08, 2009
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
720 and 1080 resolution
depend if your TV dos 720 & 1080 ill look into this more for ill get back 2 u soon
Aug 16, 2008 | Toshiba 42HP95 Television
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have a 4 year old Mitsubishi WD-57831. Lately, when connected to my cable DVR via a HDMI, the picture flashes on and off and some stations don't come in at all. I changed the cable box 4 times, changed...
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Aug 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Poor signal. Check connections at all Coaxial connectors. Should be tightened. Unplug a/c from rear of DVR for 30 seconds. Allow time for DVR to reboot and update. Try again. If not resolved, call tech support for your cable company. May have to boost your signal.
Jul 29, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
TV Guide will not update
The problem is not with your machine. TVGOS information is embeded in part of the a PBS analog signal. With the covnversion to digital, some PBS stations are not sending this data out anymore. Also, some cable companies are not converting the digital signals to be sent out on the old 125 analog channels.
If you try to chase this down with the Cable Companies or PBS techs, you will get; blank stares, help desk happy voices, it's not our problem, we don't support TVGOS, etc.
Personally, I think that the digital transition has killed TVGOS. It ain't comin bak, no more, no more.
Start looking for a replacement DVR that is easy to program.
No, wait, try to find one! Blue Ray along with Cable Company & Dish Network, etc. DVR's have killed the market for a stand-alone DVR's.
But there s always TIVO $$$
Mar 01, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
HDMI inputs stopped working
I had the same problem with the HDMI connected to my HD cable box DVR. We called the cable company and he changed the box and the problem remained. He said there was something wrong with my TV.  The component (5-wire) jacks on input 5 work fine.  A few months later i got the 'green tint" problem and the tech came out to replace the whole optical box.  I asked about the HDMI problem and he said that the Sony protocol for HDMI is the problem. It will "talk" to some hardware and not others. He has not found a fix, except to use the other A/V inputs and abandon the HDMI (#7) input.
Mar 22, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
Feb 05, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Insignia IS-LCDTV32 32 in. Television Logo
64 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
