Question about Sony DAV-S500 System
Irregular performance... The last two times I used the DVD player, I had problems. The unit is 6 years old and I have never performed any maintenance such as cleaning, etc...I have not checked the manual but I assume there must be some periodic cleaning suggestions. One issue was in the middle of the movie, the system stopped and on the DVD monitor "Protected" appeared and the machine stopped. It took several attempted to eject the DVD. This has never happened before. Tonight, it took several attempts for the disc to load and register. The disc loaded, made a rubbing sound when entering and did insert but on the DVD monitor "Insert Disc" appeared. The system finally worked when I began playing the disc while the TV was on versus the video... I then switched to Video and the system worked fine. Any suggestions?
    Problem Solver:
  • 8 Answers
Sounds to me like your laser is gone.
Some discs are harder to play than others as some are multilayed, check online as to whether it is suitable to use laser cleaners these are like discs with soft brushes attached, you can get them from pretty much any computing place, i wouldnt know whether its sensible to use on a DVD player, but couldnt hurt anymore eh?
Posted on Jan 08, 2009
We have a 40-pt Crosley purchased in 2005. Gave us 6 years of perfect service. It stopped working recently; it will not turn on. No lights, no response...dead. Is a unit this old worth repairing? ...
Shinn, I'd say you've gotten your monies worth out of 6 year old dehumidifier. Most of the time, it's more expensive in the end, to repair one than it is to purchase a new one. With that said, I'd vote for purchasing a new one. Just take as good of care of the new one as your did the old one. Obviously, you performed preventive maintenance on the old one and that's very important. Which makes you the exception to the rule, that most consumers don't take care of what they have and are astonished when an appliance fails.
Keep up the good work!
Mar 26, 2011 | Crosley Dehumidifiers
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
. I bought an Amcor AWS090HR a couple of years ago
?Call pridiom group 201-266-8234 option 2 for warranty and service
?*Self Diagnosis Functions*
Our company provides the thoughtful services for customer,air conditioners had been
installed self diagnosis system to display the information for the units.
INSTALLATION & REPAIR GUIDE
Split Wall-Mounted air conditioner
8
*According to the service conditions and operating environment , the inside of the air conditioner
will become dirty after several seasons (3 to 5years ) of service , resulting in decreased operating
performance .Inspection and maintenance are recommended in addition to usual cleaning (The
air conditioner can be used for a longer period and without anxiety .)
*As to inspection and maintenance , consult your dealer or any one of business offices of dealing
companies .(Service charge is required in this case .)
*We recommend to perform inspection and maintenance during an off seasons.
*Choose the place where hot air and operation noise from the outlet of the outdoor unit do not annoy
the neighborhood .
*Things left near the outlet and inlet of the outdoor unit cause malfunction or increased operation
noise . Do not leave obstacles near the outlet and inlet .
*If irregular sound is heard during operation , consult with your distributor .
*Inspection and Maintenance
Note:Above self check information is commonly applicable in our most air conditioners,but some
are special,you can refer to the User's Manual for information or contact the dealer or authorized
maintenance people for help.
Digital self-check code/
(Polychrome screen self-check code)
Hint to defrosting Flicker 1 time/1s
Hint to defense
against cold wind Flicker 1 time/3s
Failure of room
temperature sensor
Failure of coiled
pipe sensor
Abnormality of
outdoor unit
Without feedback of
internal fan motor
Zero crossing signal
without current
External feedback
failure
Overheat protection
Water pump failure
Self-check code of luminotron/
(Self-check code of running lamp)
Flicker 2 times/4s
(Flicker 2 times/8s)
Flicker 3 times/5s
(Flicker 1 time/8s)
Flicker 4 times/6s
(luminating)
Flicker 5 times/7s
(Flicker 6 times/8s)
Flicker 6 times/8s
Flicker 7 times/9s
Flicker 8 times/10s
Flicker 9 times/11s
Self-check
information
Indicates "dF"or defrosting
indicator displays
Fan motor picture not running
E2/(L2)
E3/(L1)
E4/(E5)
E5/(L6)
E7
E6
E8
E9
Nov 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Will play normal dvds but says any blu ray dvd is incompatible,brand new plaer only been used about 6 times to play movies .It worked fine last time it was used.
Return it to the seller. This unit is clearly faulty and does not perform as per manufacturers description.
You are within your rights to have this REPLACED rather than repaired.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sharp AQUOS Blu-ray Disc Player
Cannot write onto CD or DVD
try updating! Nero version 7 is old and cannot work in XP with any upgrade past sp1 If you have Vista now that is another reason to upgrade Nero There is a version 8 now
Jul 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Receiver is beginning to chirp/buzz.
tighted loose circuit board and rear panel screws
Jul 14, 2009 | Yamaha HTR-5660 Receiver
DVD player will not play Disney made movies
I don't know what BOLT is, as I fixed my last DVD player 6 years ago at Sony. I think the Disney Format is Newer than your DVD player can read.
I remember Sony had a $5000.00 when new DVD player that was the first generation of DVD's. We would get them in for repair and the guy would say "My Radio Shack $99.00 plays all my DVD's but this $5K FIVE YEAR OLD unit won't play them....
There was NO fix for the problem. The New DVD's were beyond the capability of the 5 year old unit.
SO.. Is the Disney DVD a Blue Ray Disk? Or a new format that your older DVD can't read?
AL
Apr 26, 2009 | Spectroniq Televison & Video
LG DR6921W DVD Recorder. Unit will not recognise DVD discs (Blank or commercially recorded)but will recognise and play audio CD's. Unit is 3 years old.
That is most common problem of DVD player recorder,when getting old cannot read DVD discs,only video cd and audio cd,sometimes does'nt read video cd also. The problem is in inside of the unit the DVD processor is defected already or maybe the solder is crack, need to resolder again or reheat the processor solder, or that processor change with a new one,so the performance will back again,good as new.The lense of that unit is good,i can assure that.
Jun 14, 2008 | Audio Players & Recorders
Gradual decrease in water temperature
Rebuild the watervalve or replace it. 6 year old unit means its probably one of the 125 series. Probably a polymer gray water valve. Pay attention to the venturi, most likely its very dirty. You can get instructions off the www.boschhotwater.com websight to rebuild this.
Feb 20, 2008 | Terminator Aquastar 125FX Tankless Water...
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Aug 13, 2007 | Philips DVP642 DVD Player
Sony DAV-S500 System Logo
147 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
