Question about Maytag Atlantis MAV6000 Top Load Washer
Timer won't stop
Maytag SAV2655AWW timer always ticking!
Wwasher runs through stop points and continues running through cycles
  • Thomas F. Schneider May 11, 2010
    Defective timer. Replace it.
    Problem Solver:
  • 15 Answers
If the timer is still running thru stop points and continues running thru you timer is definitely bad.YOU EASY PURCASE ON AT YOUR LOCAL MAYTAG DEALER OR ONLINE. Glad to be of service.
Posted on Jan 08, 2009
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
The dial stops at 3 different spots and the machine continues to run until the dial is advanced a little. It does not always stop at the three usual areas but always the first. Is there a way to clean...
The clock motor on the timer is failing to advance through the cycle. If you can hear a hum, you might be able to take the clock motor off the timer and clean it up and lube it.
May 12, 2011 | Maytag Dishwasher
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Timer problem?
HI!!! You seem to have a problem with your timer..Good luck..If it stops and then you have to start it up then change your timer..Good luckk.
Jan 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
