Question about Dell A960 All-In-One InkJet Printer
Unlock printer i have a problem unlocking my dell a960 printer, i unlocked the scanner lock yet, the problem persists indicating the scanner is still locked.Plese, what should i do?
  • Anonymous Jan 02, 2008
    Where is the unlock printer button?
  • JKITY May 01, 2009
    MY DELL A960 READS 'UNLOCK SCANNER THEN PRESS POWER' I HAVE DONE THIS SEVERAL TIMES WITH NO LUCK. ANYONE????
    Genius:
  • 2,985 Answers
Work the lock several times. Make sure there is not more than one lock. Dell web site Tech Support Look in on www.fixyourownprinter.com
Posted on May 31, 2007
How do I fix an unlock scanner error?
I work for Dell's Social Media Team and would like to you help with your question.
Please turn off printer. Unplug the power cable.
Inside the printer output tray (under the scanner), there should be a blue slide switch on the underside of the scanner housing. The blue button is on the underside of the section where the printed papers would emerge. This is the scanner unlock switch.
If issue persists, please contact our printer support at 1-877-335-5767 for further assistance.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Jun 03, 2015 | Dell Mfp 1600n All-in-one Laser Printer
Printer says to unlock scanner
to unlock scanner this is a little lock where the copy come out. this is located on top this is a blue lock to your left side
Feb 22, 2010 | Dell 1600n All-In-One Laser Printer
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Sincerely,
Jeeth
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
Dell AIO Printer A950 telling me to Unlock Scanner.
Open the front cover of the printer so that the ink cartridges are visible and the green kickstand is supporting the cover.
Locate the green switch to the left of the kickstand. (Figure 1)
Push the switch towards the back of the printer, you're now unlocked.
Hope this helps!
BTW: Got these steps from here:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&treeid=74D6F97A889B49B2B4845D62F86B269E&journalid=663B9EF8BEECF09CE040AE0AB5E17297&Query=dW5sb2Nr&SystemID=PRN_ALL_A960&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Mar 29, 2009 | Dell A960 All-In-One InkJet Printer
Dell 1815dn all-in-one-laser
There is a little tab that locks the scanner bar.
Open the flatbed cover, and you'll see it in the left corner closest to you.
To unlock it, reach your hand (palm up) into the area the the paper comes out in.
Slide the tab to the unlock position (you'll be able to see it through the flatbed area.
If you need a complete manual for the MFP, you can go to the Dell website, in the support area, and download a copy of it.
Aug 11, 2008 | Dell 1815dn All-In-One Laser Printer
I Don't Have The Key
Darryl - lift up the top part of the scanner body (the silver part should separate from the black base) and let the kick-stand support the top part. Then look underneath the top part; there'll be a green tab sticking down from the top. If you look closely, you'll see little icons next to it that look like padlocks, one in an unlocked position and one in a locked position. Push the green tab away from you so that it lines up with the unlocked padlock, and that should do the trick.
Feb 10, 2008 | Dell A960 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Unlock printer
the unlocking will refer to docking clamps that lock the scanner into place for transit, liik inside or underneath for a lever or switch to unlock
May 31, 2007 | Dell A960 All-In-One InkJet Printer
Printer does not work
remove the lock from scanner,switch on scanner and restart you computer. bye
Oct 29, 2006 | Dell A960 All-In-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
222 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
