Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Cannot use LCD for making inputs
I cannot use the LCD. It seems to be blocked. On the screen are displayed: "clock set", the "x" button, the "ok" buton, two arrows, up and down. When I tried to touch the screen nothing happened. Help!!! Thank you.
  • 188 Answers
It seems that the touch screen of your camera has damaged. Once replaced the camera will start working fine.
Posted on Oct 02, 2007
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
How do I set the time on my logitech iPod dock?
1. Press the power button on the dock. Press the Select button until the large clock is displayed on the lcd screen. 2. Push and hold the select button until you see the clock time display. 3. Set the time using the arrow buttons.
Mar 05, 2011 | Computers & Internet
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
Having Difficulty programing Woods Brand electrical timer !
Download Woods manuals
59377 manual
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Program timer
Do not hold down PROG button
Press PROG button once to finalize ON time for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Press PROG to advance to program 3 through program 8
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Oct 07, 2010 | Woods Industries 59377 Indoor Digital...
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
LCD screen SDM-HS75P has a message on the center displayed all times.It says INFORMATION MODEL:SDM-HS75P SER.NO:1022769 MANUFACTURED:2005-18 and it stays on top of windows all time. How can I take this...
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Mar 04, 2010 | Sony (141857441) 15 in. Flat Panel LCD...
INFORMATION WINDOW KEEPS DISPLAYING ON THE SCREEN
Jul 19, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
166 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
