Question about HP Photosmart C6180 All-In-One InkJet Printer
Black ink cartridge needs to be replaced but will not clear
Need to change black ink cartridge have done it three times but error message will not clear and printer will not print fax or scan
Put printer in water
Posted on Jan 09, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printing message problems
its not an ink problem but a mechanism problem many things can lead to this: say bad film, week rollers and etc so loos the nprinter n make sure all the mechanism are in place.
May 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Color, black ink cartridge error
contact epson support
they may replace your cartridge
Oct 24, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
