Question about Acer AL1715 17" LCD Monitor
Acer AL 1715 monitor flashes 2x and dies
When I turn on the monitor it flashes a white screen twice and then does not start. When flashing the green light is on. After flashing a yellow light is on. The screen does not work after this.
  • 31 Answers
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Posted on Jan 08, 2009
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
ACER AL1706 powering up, green power light flashes once a second, faint 'flicker' on screen, eventually starts up with the Acer logo, and runs normally.
You may have dying power supply due to bad DC filter caps.
Please see failed ACER and other monitors to see if you will want to DIY repair.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Aug 28, 2010 | Acer AL1706b 17"LCD Monitor
ACER AL 1715 GOES OFF AND ON BY ITSELF FOR DIFFERENT LENGTHS OF TIME. SCREENSAVER SET FOR 15 MINUTES, REPLACED MONITOR CABLE. NO EFFECT THIS HADHELPEDIN THE PASS
sbra454016, Monitor has internal problem on "switch-mode-power-supply/ccfl inverter supply" printed circuit board. Check smps/ccfl supply board. Read my fixya profile to understand problem or skip the reading and trade-in for new wide screen unit. Reading is free. 12fixlouie
Mar 20, 2010 | Acer AL1715 17" LCD Monitor
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
AL1715 Acer flashes twice when starting up but does not go on
blown capacitors most likely cause, replacement of the blow caps on the main power board is advised
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
Acer AL1715 17" LCD Monitor Logo
525 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
