Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
ERROR MESSAGE ON FRONT LOAD WASHER
I HAVE AN ERROR MESSAGE ON MY FRONT LOAD WASHER E10. IT'S A FRIGIDARE BRAND. WHAT IS THIS?
  • 3 Answers
I had to replace my keypad display after it got fried by the steam. Call Fridgidaire and let them know you've seen numerous people on the internet with the same issue and they should cover it under warranty. The part #154554401
Posted on Apr 01, 2009
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidare galllery series washer when i wash sometimes it wont spin and it says E10
Hello, The E10 error code indicates there is no cold water coming into the machine, either this is because the inlet valve is bad or there is a kink in the cold water line or a blockage in the filter screen where the cold hose hooks up to the machine or one of the kids turned the cold water off at the back of the machine :) Either way you should check everything I have listed, If you can't find a blockage replace the inlet valve. If you have any questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 09, 2009 | Frigidaire GLTF2940ES Front Load Washer
My washer is showing a code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Error E10
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on SEARCH
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
STEP 6 Also access and save, or print PDF files: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, OPERATING INSTRUCTIONS, and PARTS MANUAL(These PDF files will help in replacing, repairing, and maintaining your machine.)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
May 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
321 people viewed this question
Top Frigidaire Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
