Question about Roper REX3614KW Electric Dryer
Runs for five minutes, then shuts off...
Is it the timer? This problem is the same for all settings - set the dial, push the button, and it runs for about five minutes, then shuts off.
Will check more possibilities this weekend, but the air flow seems to be fine.
Any suggestions?
  • redifredy Feb 24, 2009
    I push the start button and as long as I hold it the machine runs. During it's running I can hear clicking. If I let go of start it stops. Any ideas?
  • Duane Grant
    Duane Grant May 11, 2010
    what does it sound like when you try to restart it? if it groans when you try to start it, its the motor.
  • Roper Master
  • 8,220 Answers
Bad motor is all it could be.
Posted on Jan 20, 2009
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
Everytime I put the pre-sets for the timer, it does'nt keep time. COuld you assist me or provide me with someone who can repair?
I can assist you.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
The 'pre-sets' are confusing.
Do you mean tabs or trippers?
Tork 8601 is a 60 minute cycle timer.
The dial should make 1 full revolution each 60 minutes.
Trippers or tabs located on dial are pushed up or down to set on-off schedule.
If dial is running slow, then clock motor has gone bad.
If dial is running on time, then trippers are worn down or timer parts are worn down.
Either case when timer stops functioning, buy a new timer for $110.
If the clock motor was available, you'd probably spend $60 for the motor.
http://www.farmerboyag.com/time-clocks/23080024.asp
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Same Intermatic timer is C8865 for $88.35
http://www.amazon.com/Intermatic-C8865-1-Hour-Repeat-20-Amps/dp/B000GHKO8K
Jul 18, 2011 | TORK Variable Cycling Timer 8601
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Explain in plain english how this works. Set time on face rotating dial clockwise.. push in pins to on and off positions. It seems to screwy unless timer runs counterclockwise, Set time at 5:30 AM amd go...
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Dec 04, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
Can I set my timer to run for 15 minutes when I push the start button and then shut off
There is no reason why not, usually one can increment a timer in one min intervals, so simply set your timer for 15 "Intervals", or 15 Mins, and you should be OK.
Aug 31, 2010 | Woods Hardware & Accessories
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Roper REX3614KW Electric Dryer Logo
90 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
