Question about GE 5803P Multi-disc DVD Player
Won't open or load
The player says it's opening and closing, but it doesn't. It also says it's loading, but it doesn't. It's not turning at all when I try to switch to different discs. I tried unplugging the player for several moments to reset it, but that didn't work.
I did fix it! The solution turned out to be pretty simple and easy!
Here is how:
1. open the box by unscrewing
2. rotate the multi-DVD holder counterclockwise (the problem was that the DVD spinner under the circuit plate was somehow stuck over the DVD holder)
3. you'll hear a click sound
4. turn it on and the problem solved!
rluo
Posted on Jan 23, 2008
An other's suggestion to "shake it" sounded somewhat low-tech, but in the absence of any "high-tech" suggestion and nothing else working, I shook it around. Now it powers up, opens, closes. Expectations of a long and fruitful usefulness are VERY low.
Posted on Dec 31, 2007
  • 23 Answers
Inside your player are different sets of rubber belts. one or more of which is broken. the player won't actually recognize the issue and will say it's doing whatever you want it to. seeing as it's a changer you're not gonna be able to just pull it apart in pieces and work it manually like I did with mine (lol). you're just gonna have to break down and either have it fixed or buy another one.
Posted on Jun 06, 2007
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
GE 5803P Multi-disc DVD Player Logo
227 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
