Question about Dell Latitude D505 Notebook
How to get online
I now own my 1st laptop and I was wondering what do I need in order to go online if I take it, say, to the park or someplace like that? Do I need some kind of a card, or something?
Thanks
CBussey
You need some kind of wireless internet card that can pick up signal from anywhere, unless there is a wireless internet connection nearby that you can pick up.
Posted on Jan 08, 2009
95 silverado parking lights&dash lights keep blowing fuses
got a short someplace and only a person that can look for it can fix it .
Aug 05, 2015 | Cars & Trucks
Lost password
A few things can be happening:
1. You have a DVD but only a CD Drive
2. The DVD is no good
3. Your drive is not working
You can also make a bootable flash drive to accomplish this:
http://pcsupport.about.com/od/windows7/a/install-windows-7-usb.htm Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 21, 2014 | Acer Aspire 7720-6569 Notebook
For Atheros PCIE Ethernet Controller... check cable connectionPXE-E63:error while initializing the NICPXE-MOF:exiting intel PXE ROMNo bootable device-insert boot disk and press
Sounds like you are trying to boot from a lan or someplace other than your hard drive. Turn the computer off then turn it back on and watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence then hit that key. You have to hit the key when you see the message or it will not work and you'll have to reboot to restart the process. Select the Hard Drive as your boot source and then see if it boots up all the way. If it does, you will have to do this each time you start the computer unless you make a permanent change to the boot order or boot sequence.
To make the change permanent, turn the computer off and restart it. Look at the screen for which key it says to hit to get into the Bios or System Setup then hit that key. You have to hit the key when you see the message or it will not work and you'll have to restart. Once you get into the Bios or System Setup look for the Boot Sequence Tab or Settings and go change the boot sequence or Boot Order. Make the cd drive 1st, and the hard drive 2nd. This is the normal boot order or boot sequence. Just make sure when you boot the computer you don't have a music cd or movie dvd in the drive or you'll get an error because the system will try to boot from the cd/dvd drive 1st.
Jun 10, 2012 | Computers & Internet
I don't know how to download microsoft office thru the web. please instruct me how..
You can't do it via the web, you need to buy a retail version at a store that sells computer software or order online from someplace like amazon.com
Sep 27, 2010 | Computers & Internet
Im looking where to put oil in automatic gearbox vw golf
there is a plastic cap facing the front of the car on the gearbox. this must be removed in order to fill autotrans fluid.
it is important though to ensure that the trans needs oil.
this is established by getting the car to running temperature and running the gears from Park to 1st a couple of times, then remove the screw on the bottom of the trans sump. a small very amount of oil should spill , about 20/30ml. if more than this comes out then the oil level is adequate.if only a small amount comes out then you should top up until the oil spills from the hole.
this must be done with the engine running. and ensure you use the OEM recommended oil for VW.
ensure the car is in park and wheels chocked. please be safe!!!!
run the gears form park to 1st and back to park a couple of times.
Nov 21, 2009 | 2000 Volkswagen Golf
92 Taurus-Not shifting into 1st, but once engaged, shifts smooth
Had that problem on a 93. There is a plastic piece inside the trans that cracked and needs to be replaced...=...Trans rebuild.
Mar 25, 2009 | 1992 Ford Taurus
I need help with my computer
yes put xp cd in go in bios 1st then set boot order to cd 1st top of list ok use plus mini keys to push it up then save changes rebooot in to cd xp hit any key then let it do its thing then it will ask u to formatt or repair or del partions ok u can del partions add new partions then formatt that then boot into xp ok fresh then update and install all drivers k
Jan 11, 2008 | Acer Aspire 3000 Notebook
Pioneer D2
Found this online:
In order to watch the AV source in the AVIC-D2 or to have all the NAVI function while driving you must do the following:
1. Ground the original parking wire (Must Do)
2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it.
Nov 07, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Dell Latitude D505 Notebook Logo
52 people viewed this question
Alun Cox
