Question about HP iPAQ HX2790 Pocket PC
My hp ipaq hx 2790 don't read the memory cards
I put a sd and cf memory cards and don't read
  • cortez_adolf Jan 09, 2009
    no this is a present for this holydays the sd is 4gb PNY the other is compactflash Lexar 2gb
  • 42 Answers
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Posted on Jan 08, 2009
I just bought one 4BG SD card for my Hp Ipaq HX4700, but its dosen't show up. Please give me the suggetions, how can i use it ? Thanks in adnavce.
Use a CF-SD/SDHC adapter and use the CF slot. AMAZON sells it for under $12.00. I am using a 16GB SDHC right now.3_7_2012_7_17_35_pm.jpg
Aug 25, 2011 | HP iPAQ HX4700 Pocket PC
Can i use windows vista with my ipaq 3835 pocket pc and what is till the memory expandable upto
No, you cannot use Windows Vista on your iPAQ.
I am not 100% sure but, I have seen products made before the whole HD SD cards not being able to use them so, I would stick to the regular SD cards which go to 2GB.
Feb 09, 2010 | HP iPAQ H3835 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
SD Card not reading
I had this problem once and found after tedious looking that one of the pins was bent inside my HP 3715 PDA. I used a very small needle nose and a safety pin and pushed it back in location. Has been working ever since.
Mar 22, 2008 | HP iPAQ HX2490 Pocket PC
Biometric fingerprint
In my iPAQ 2790 , I found an icon in SETTING ( HP Protect-Tools) that help to configure the security in your devise.
Mar 22, 2008 | HP iPAQ HX2790 Pocket PC
Ipaq 2400 series will not recognize Compact Flash card
Hello :-) I have a HP Ipaq 4350 and something similar like this happened to me. Except when I tried to take out the SD and put it in again the screen would go different colors and I would have to reset. But sometimes the SD will not get read because of the way you in and outsert  it. Do you push down on the SD card and it will pop automatically or do you pull out the SD card. Because if you pull it out that might be your problem because if you DO pull it out it can damage the metals that read the SD card. Now If you do pull it out  I'd recommend for you to insert the card and then pop it out and reset your device. If you do not pull it out you should go into the finder app on your Ipaq and see if that finder finds you SD card. If it does that means that your program is the problem and that its not fully compatible with your ppc or your specific SD card. Im sorry if this doesn't resolve your problem.
Dec 31, 2007 | HP iPAQ H2210 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
SD card slot stopped working
Really maybe you don't know a lot of fixya in the philippines. Try to send your device here in Dipolog City.
Nov 20, 2007 | HP iPAQ H2215 Pocket PC
IPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
CF GPRS Modems for PDA??
Update to Window Mobile 5 and it should fix it. You would also need a GPS update from HP website for the PDA.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX2790 Pocket PC Logo
333 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
