Question about Philips Brilliance 151AX Monitor
Flashing Monitor Monitor periodiclly flashes with, I want to say brite light to black. You can see the screen very breifly behind the flashing. There doesn't seem to be any pattern or particular thing that triggers this. When it first started I could Ctrl Alt Delete and that would stop it. We thought maybe it was a game that my sister bought ,but we have been playing that game for months and nothing happened. In fact we had both gotten to the same point in the game an could not advance any farther. (Hot Lava Mumbo Jumbo 7 Wonders of the Ancient World). Now the only way I can stop it is to turn off my computer the hard way. Is my monitor going bad? It's pretty old or is this a hard drive problem. Hope you can help me. Thank you Phyllis Brandt
How to do OSD main menu unlock
Posted on Dec 16, 2009
    President:
  • 2,692 Answers
Substitute monitor to find out. I doubt it  is a hard drive problem. It could be a video card problem. Borrow a monitor or get an old CRT one (available for almost nothing now) We pay to have then removed or desposed of in our city. If the substitute monitor does nto do it then it is the monitor going bad, as you say. If the substitute one als flashes I woud go for the video card.  If video card happens to be an "On Board: type consider buying one to install in  a open slot..
Posted on Jan 08, 2009
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I'm having problem with my monitor. It's showing a black screen and flashing. The on and off button is flashing green I see white flashing althou my screen is black. I tryed another monitor and it works...
You shoul check the cable between the video card and the monitor. Check the plug for bent or broke pins. If it is not separated from the monitor, the repair might cost you more than a new screen.
Oct 15, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Philips Brilliance 151AX Monitor Logo
302 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
