Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool electric dryer won't stay on
After selecting the desired setting and time on our Whirlpool Electric Dryer Model #LER7646QG1, we experience problems when depressing the push-to-start knob. The dryer seldom continues to run through the full cycle without several attempts at turning the timer knob while pushing the start knob. Most of the time it will stop running as soon as we release the timer knob, but sometimes it will run for a few minutes and then stop. There is a significant price difference between the push-to-start relay and the timer, one of which I believe is the cause of my problem. Depending on the cause, I may want to replace rather than repair.
  • 2 more comments
  • rockit4 Jan 08, 2009
    The only thing I've done is remove the back of the console and inspect wires and connections.
  • sharpshot90 Jan 29, 2009
    I have the same problem but mine is a 'Hotpoint'
  • Anonymous Mar 11, 2009
    We are experiencing the same issue. We have some drying settings that will not even work now. We are down to just "cool down" setting which only last about 15 minutes. It's crazy. We cleaned EVERYTHING, checked the door sensor. I am here online trying to get an idea of what the problem is to aide in my dicision to fix or buy new. What are you guys doing?
  • Thomas F. Schneider May 11, 2010
    Have you tried jumping out the relay,only as a test?
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Posted on Jan 26, 2009
  • 91 Answers
SOURCE: Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
Posted on May 28, 2009
  • 58 Answers
SOURCE: Whirlpool 110 electric dryer will not keep running
If you have replaced the door switch you have had the top open, right? Now find the overheat limit switch, somewhere on top, just behind the drum. Use an ohm meter to check it. It should be closed, 0 or near 0 ohms. If the dryer overheats this switch opens and stops the dryer, same as the door switch. usually in the same circuit. If this is good then the run switch on the motor is probably bad. If the circuitry thinks the motor has stopped everything goes of falso. The push to start switch bypasses all of these and lets the motor start to turn. If any of the three are bad when the start button is released the dryer stops again.
Posted on Jun 06, 2009
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Whirlpool electric dryer model WED5100VQ1 Dryer won't heat and timer dial won't move once it's set on desired dry time. Are these related? Any ideas?
For anyone who may be interested (this post is a little dated). I just diagnosed one of these machines today. Dryer runs with no heat. First thing if you don't have an ohm meter get one and learn how to use it (easy). Check for 220 (240) volts at receptacle then ohm your element then check your thermal cut off( at top of element housing, if these check out good then the timer is the likely culprit ( what I found today). There is a schematic inside the console that shows you what to check.
God bless.
Nov 02, 2010 | Whirlpool WED5100VQ Electric Dryer
I have a Whirlpool LER4634J Electric Dryer that has stopped mid-cycle and will not restart. I know VERY LITTLE about dryers so please use plain language if you give suggestions about how to fix it. Thanks!
1. Does it have electric power? Is the breaker or fuse good? Is the power plug loose?
2. Is the door to the dryer ajar? Please open and close it a few times to check this.
If this doesn't help, you may need new or repaired parts. The timer motor that turns the dryer switch may have failed. The clutch that allows you to turn the select knob for the different dryer cycles may be slipping and have failed. The start button that begins the dryer cycle may have failed after a temporary power outage. The door switch may have failed. The particular switch in the dryer cycle setting you are using may have failed (Other cycles may still work). The dryer thermostat(s) may have failed (prevents too hot/ over-heating). Follow the wires from the "heat selection switch" to find thermostat(s) in the hot air duct. They "turn ON" when too cool and "turn OFF" when hot enough. Mechanical switch contacts can "melt together" and stay always ON. Or switches can get pitted and stay "always OFF" after enough ON/OFF cycles. If pitted contacts happen, you can see this on them. Sometimes a finger nail file (I do not recommend a metal one) can shine them up again. Solid state (electronic) switches have to be tested with a meter or something else to see failure. Please don't do work on electrical or any other problems while the dryer is plugged in or still hot. Good luck. Your mileage may vary. ;-)
Aug 03, 2010 | Whirlpool LER4634J Electric Dryer
REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
I have a type DHZN-ELE-2406024-EL54 model
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
288 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
