Question about Hotpoint HSS25GFP Side by Side Refrigerator
Compressor and water are hot!
We first noticed a problem a couple weekes ago. The water from the dispensor was very hot for about the first 4-5 fl. oz. dispensed, then was cool. I later discovered that the compressor was heating the water line. The floor directly beneath the refrigerator was very warm, so I pulled out the refrigerator, took off the cover, and cleaned out the dust and lint. Surprisingly, there was not very much dust, etc. to remove. The black compressor tank is very hot to the touch and a bit noisier than it was several months ago. The fan is running fine. The unit is only two years old. Is there any danger of a fire from the heat? What do I do? Thanks!
  • Jay OBrien Jun 02, 2007
    The GE authorized repair person came over to check the frige and said there's nothing wrong with it! Luckily, it was a "no charge" visit. He mentioned that compressor heat of 150 degrees or higher is normal, and that the strongest symptom of a bad compressor is high heat along the freezer / refrigerator compartment divider. Fortunately, my unit did not show have this problem!
    Even though there wasn't much dust stuck to the fan, I think cleaning it made a big difference. The water coming from the dispensor is not nearly as hot today as it was before.
    Thank you for your help, and I hope my post is helpful to others.
  • 883 Answers
Re-charge the freon. this will cool it down.
Posted on May 31, 2007
Poulan Leaf Blower red hot muffler
you need to turn the Hi screw on the carb in 1/4 of a turn.
Jul 22, 2013 | Poulan Garden
Devilbiss air compressor Running hot and low pressure
Chris:
Sounds to me like you have an air leak somewhere. When the compressor motor runs for too long a time, it's 'gonna get hot! Disconnect the fittings one at a time and use Teflon tape at each air connection. Check for leaks using a soap and water solution at each fitting.
Jun 02, 2013 | DeVilbiss Air Tools & Compressors
Just replaced the motor and pump, 3 weeks ago.
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$
May 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I bought a 2000 KIA SEPHIA a couple of weeks ago and have noticed that when I put my defrost on that my air compressor also comes on along with the air conditioning light in the car, would anyone know...
It should do this or else in cold temp your windows will stay foggy and in cold temp you can still control the temp from hot to cold.It's ok suppost to work that way.
May 13, 2010 | 2000 Kia Sephia
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
