Question about Tomtom One Europe v2 GPS Receiver
Tomtom one 125 easyport mount won't stick
The directions say it will stick to glass... but it wont stick to anything and i dont know what to do. there is a little thing that looks like kinda like a suction cup. but it wont stick to anything
  • 3 more comments
  • dcraig792 Jan 15, 2009
    Same problem with the 130, new out of the box
  • Anonymous Jan 30, 2009
    same problem, wont stick to anything
  • zbd74 Feb 20, 2009
    I can not get the suction to stick to the windshield, or to the plastic dash pad. I've trying wetting, drying, cleaning. I've held it tight, loose and in between while rotating the dial. I can see the action when holding it up, still no attachment
  • pisque Mar 08, 2009
    Exact same problem.  the easyport mount won't stick to anything
  • Anonymous Apr 26, 2009
    i cant get my Tomtom one 130s mount to stick to anything!!!!!!! its so frusturating. have you found any resolutions?
The soft vinyl suction cup has two ears. Behind the ears are two depressions in the mount ring. The vinyl shapes itself into the depressions and forms two tiny gaps when you try to stick it to the windshield.
Place a pencil or other small round object between the ring and the soft vinyl part. Bend the vinyl outward. You may not be able to see the difference, but it should now stick
Posted on Sep 05, 2009
Check out this link...It's a movie of how the EasyPort is supposed to work...looks like the key is turning the ring on the back of the suction cup clockwise while kissed up to the glass
http://www.clubtomtom.com/general/a-closer-look-at-the-new-easyport%E2%84%A2-mount/
Posted on Jan 31, 2009
It won't stick!! No kidding!! They drop all the time after a little bump or a turn!! We found the best solution for this problem. We use a new product, so called "SlapOn" space age adhesive on the dashboard and just throw our GPS directly on it, and it sticks and stays!! Basically, you can throw a lot of other things on it, too, like iphone, cell phone, or lighters. It can be removed anywhere on the flat surfaces, reused hundreds of times and against the water and UV under extreme weahters. Forget about the suction cup!! It never works in my bathroom or anywhere for too long anyway!!! Or, you can use SlapOn on the back of the suction cup to stick on the windshield. That's the only way that can help the suction cup that won't **** stay...... Look at the picture attached. SlapOn is basically just a piece of very strong and weird vinyl adhesive, and the cell phone sticks to it. It doesn't stick on my hand, but it just stays. dlcraig@comcast.net
Posted on Dec 18, 2009
I had the same problem and fixed it by running a letter opener around the suction cup where it is glued to plastic. After that while push hardturn the dial clock wise about halfay though the turn push down on the two ears and finish the turn.
Posted on Jan 08, 2010
I had the same issue out of the box.
  1. If you first press it against the glass, then first rotate the the dial counter clockwise first, the suction cup "grabs" the glass and you'll feel friction,
  2. then turn the dial clockwise as normal to lock it. Mine holds after this procedure.
Note: on the counter clockwise turn, do not turn too far (only a few degrees as you feel the friction) and definitely no farther if you hear a click, otherwise you will disassemble it (like I did) and you'll spend 15 minutes figuring out how to put it back together. If you do disassemble by accident, put the spring in the center and align the three start threads, but offset the start by one thread groove so that when assembled the slot in the dial aligns around the mounting/pivot arm.
Posted on Mar 12, 2011
TomTom does not stick to window any longer
That is pretty typical.
If you want to mount it to the window, then make sure the glass surface is completely clean. A generous amount of saliva on the suction cup will keep it up on the glass for a while.
You are better off using the adhesive backed suction cup disks and mount it to your dashboard.
Jan 04, 2017 | Tomtom GPS
Do i use both the hard plastic adhesive disc or just the one that holds the tomtom to fix onto windscreen.Mike.
The disc is for attaching your unit to the dash. On the glass, you just need to stick the mount to it. Make sure the glass is perfectly clean or the mount and GO720 will eventually fall off. Also the oem mount is just a general pain at best. I went with an aftermarket mount to eliminate the problem.
Nov 20, 2009 | Tomtom GO 720 GPS Receiver
TomTom EayPort mount will not stick to anything!
You will have to buy a new suction. After being in the hot car, and after suctioning up and taking down it will lose it stickingness.
Aug 10, 2009 | Tomtom One Europe v2 GPS Receiver
Cant make Tomtom mount stick to anything
you need to pull the two ears on the sides of the suction cup away from the windshield before you tighten it down. its really easy once you figure it out. hope this helps
Feb 23, 2009 | Tomtom ONE GPS Receiver
Mounting tomtom 125 with disk
first ensure that the surface you are mounting to is clean use rubbing alcohol also make sure dis surface and suction cup are cleaned. remove sticker sticker peal from sticker on underside of disc place disc on cleaned dash surface. then place mounting cup onto disk this should hold quite well if not i would recommend getting the hard plastic type velcro and attaching to dis and suction cup that works well for me
Dec 27, 2008 | Tomtom (9K00.005) (636926011532) Mounting...
Unsure how to mount tomtom on car windshield
I was perplexed by the lack of instruction as well. However, I took the unit to my car and realized that the black disk is not needed for mounting the unit to the windshield. If you look carefully at the bumpy plastic ring just above the suction area, there are two little pictures on the back of a lock; one open and one closed. With the ring in the open position, push it against the windshield and turn it to the closed position. It then sticks to the glass very well. I now just snap the unit in and out of the mounting ring that I leave stuck to the glass. I hope this helps. I assume that the presence of the black disk is to bring people closer together with digital communication.
Dec 14, 2008 | Tomtom One XL GPS Receiver
Broke screen while trying to fix to windscreen
Are you talking about the easyport mount on the XL 330S model? If so it applies fairly easily in a secure snap. When I tested out the new mount, it was fairly easy to snap on without any added pressure. TomTom has great customer service and I'm sure they'll help out to the best of their ability and if it was in fact defective, you're bound to get a replacement. TomTom doesn't want any unhappy consumers. It's a shame it broke, because it is actually a great device.
Nov 07, 2008 | Tomtom One XL GPS Receiver
TomTom XL V2 EasyPort Mount
I wish I had that problem...mine won't stick at all!
Sep 16, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
5,818 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
