Question about Intel SuperMicro SUPER Motherboard - 810 (370SEAO)
Motherboard is dead
I have two computers, both use Intel 810 motherboard with Intel 600mhz processor. The problem is that when power is plugged in, the Keyboard just blinks;nothing is on the screen,no audio, no HDD activity. The RAM is new. what could be the problem?
  • 1,066 Answers
Put the old ram back in. the intel 810 series mobos required low density (an old style) sd ram modules and may not be compatible with newer ram modules, especially 256mb and 512mb modules. if you want to upgrade ram, search the internet specifically for "intel 810 pc 133 ram" , and when looking at product descriptions, make sure the description states that that paticular model of ram has been tested in intel 810 series mobos.
Posted on Dec 24, 2008
  • 125 Answers
Check first that all installed cards are working (video card, memory). You can do this by installing on another motherboard. The install in the motherboard. You wont be able to see even the bios if THERE ARE NO MEMORY INSTALLED or if the video card is not working. If there are beeps, look in the manual what the beeps mean.
Posted on May 31, 2007
  • 883 Answers
Remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
CPU or Motherboard or both dead?
I would re-seat the CPU, and most likely the MB is not dead. You would not get any beeps if so.
Jan 31, 2013 | Intel Core i7-2600K 3.40GHz Unlocked...
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
Just built up a new system with an Intel DP43BF I can't see any Video to set up the Bios by hitting F2 the Video card is a PCI Express X16 Gforce 9500GGT Tried using a PS2 Keyboard and no luck
Please try removing everything that is plugged into the board except for power and the processor and processor fan, then try to power on the computer. Also, please check and make sure that all applicable power ports on the motherboard have power supplied. If you don't get any beep/error codes at this point, you can assume that the board is dead. If you do get a beep/error code, please let us know so that we can better help you diagnose the problem.
Thank you.
Mar 21, 2011 | Intel Classic DP43BF Desktop Motherboard -...
Hi, i have intel d945gccr motherboard.few days ago when i push power buttom to on my pc then i see no any response from that buttom i open cabinet and see that everything is ok but processor fan not...
no motherboard is not dead..
problem is with your power supply.....
repair your power supply or connect new one best is connect new one because repaired will do problem after sometime ....
Dec 27, 2010 | Intel D945GCCR Motherboard
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
> Weak voltage power rail.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
Thanks, this is an old and used computer with Intel P4 processor and intel motherboard D915GAV. It became dead silent and no component is powring up. Only the mother-boards light is ON when powered. I...
Thanks for the question its often problem in motherboard the power section in ur motherboard has the problem please consult a chiplevel engineer or if you know elctonics i can help you check the FETs the vrm section and the electrolytic capcitor for leakage
Sep 25, 2010 | Intel D915GAV Motherboard
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
It's not your processor.
Processor run only when motherboard is good. If your motherboard have no power then change it a new and this kind of motherboard are not repairable.
Oct 04, 2009 | Intel Motherboard
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
