Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
1991 KDDT207B We broke the top glass cover that fits over the oven. It's shatter proof glass. We need to find a replacement part. Any ideas?
  • markt983 Jan 08, 2009
    I broke the top oven cover for the Kitchen Aid
    1991 KDDT207B
    There are supposed to be two more numbers at the end of this model. I can't find them anywhere.
The last letters are the color, BL for black, WL for white and AL for almond. All these are followed by the number 6 so an almond color range would be KDDT207BAL6
Vince
Posted on Feb 27, 2009
  • 8,197 Answers
You can buy one at kitchenaid. Here is there 800 #. 800-541-6390
Or you can call this # for 1991 KDDT207B - partselectlogo.gif 1-888-895-1535
Good Luck and Please Rate FixYa!
Posted on Jan 08, 2009
    Sergeant:
  • 311 Answers
Yes there are links here at fixya,or other online appliance part stores.have your model and ser# ready
  • Thomas Malailua
    Thomas Malailua Jan 08, 2009
    dose it look as though there were two numbers there and now their scratch out or rubbed out.because some times the part lookup guys are wrong too.its a 1991 and my be on micro fish cards ,they can be confusing.so if numbers look like they were there that may be a problem.the manufacture dose not put it in more than one spot[i've done more than 15,000 service calls and looked at a lot of model#]if looks like weren't there try another parts supplier. God bless ,tom
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
Glass top broke, can it be fixed
They do sell replacement glass for these, you will have to contact the manufacturer to order or find where to order.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Whirlpool oven door
the rep is right as of yet there is no recalls on this problem and yes they are tempered but in my many travels I hve only seen two do this once you have the glass replaced this will take care of the problem also if you use a oven cleaner that is not made for self cleaning ovens and get even a drop on the glass it will shatter
Oct 19, 2008 | Whirlpool RBS245PD Electric Single Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
163 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
