Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I sat on the remote & now it's all snow. it's connected to a comcast cable box. help- top chef is on in 25 minutes! thanks!
    President:
  • 2,559 Answers
Manually Change the channel on the TV not the cable box back to channel 3
Posted on Jan 08, 2009
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
I'm trying to program a Comcast cable remote silver with red ok button to operate my Sony BDP-S3200 Blu-ray/DVD player and need the code please.
This is a Comcast baby - U are paying them plenty for the service - they should help you with the remote. Don't let them off the hook.
Nov 07, 2015 | Sony Televison & Video
Comcast put in a new hd box and now we cant get the remote to work to change the channel we have to trun off at tv on the side
I'm assuming you got a new remote with the cable/sat box. These remotes can act as universal remotes but must have a code input that will operate your particular brand of TV. This should allow for turning the TV on and off and controlling the volume if you are using the TV speakers. You should also check that the correct button has been pushed on the remote to operate the channel selection on your cable/sat box. There should have been a user manual given to you with the new cable/sat box that will detail the process for finding and inputting the code and other troubleshooting. You may also find answers on the cable/sat provider's website. Good luck.
Aug 14, 2015 | Vizio Vizo VP503 50-inch Plasma HD...
I used the TV remote to change channels instead of using the new SAT remote and now I can't get the tv to work...all I see is fuzz. I followed instructions from handbook to "recover" etc...still no...
more info needed... if it is the tv 1 and you have a coax cable (screw on cable) the tv needs to be on channel 3 or 4 if you have it connected with rca cables (red, white, yellow) the tv will need to be on input (tv/video, input, video, source, on your tv remote) if it is a high def receiver and tv it will need to be on the input hdmi or component (component= y/pb/pr (green,blue,red)) if it is the tv2 (if the sat remote has a blue 2 at the bottom) the tv will need to be on channel 60 or 73 if your still getting snow check the cable connections and or replace the cable and make sure you have the green light lit on the front of the receiver box.
Nov 19, 2009 | DISH Network IR Remote Control
Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 11, 2009 | Innovage Jumbo Remote Control
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Televison & Video
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
