Question about HP Officejet 5510 All-In-One Thermal Printer
HP 5510 Scanner/Copier/Fax Stuck
The printer can print just fine, however when I try to scan/copy/fax, nothing happens. The "light" that moves under the glass seems to be stuck and doesn't respond.
Everything was working fine and this just suddenly happened with no apparent cause.
  • Anonymous Jan 10, 2009
    date time incorrect, HP director will not launch. i can print a test page.
    date and time are incorrect. HP Director will not launch. I can print a test page.
    Problem Solver:
  • 3 Answers
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Posted on Jan 21, 2009
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
5510 all in one
Reinstall the drivers. You can find them on HP's site.
Oct 29, 2008 | HP Officejet 5510 All-In-One Thermal...
CANNOT SET UP SCANNER
HP Officejet 5510 All-in-one
1.) No Scan Options is coming up when I press scan
2.) Will not print from the computer.
3.) Copy is working on the HP
4.) Fax is working on the HP
Aug 19, 2008 | Office Equipment & Supplies
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
HP Officejet 5510 All-In-One Thermal Printer Logo
262 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
