Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover wind tunnel vacuum will not turn off
I have to unplug it from the wall in order for it to turn off.  The switch does not do anything.
  • Anonymous Mar 09, 2009
    the vaccum will not turn off because the plastic handle assembly is weak. The switch works but the plastic parts are worn. WHat do I do?
    President:
  • 1,673 Answers
You will have to replace the switch, Takeout the 4 screws on the back of the handle, it will slide off, then from the front, take out the 4 screws that hold the tool compartment on, it will then lift off and you can access the switch.
Posted on Jan 08, 2009
Is it safe to use Hoover wind tunnel vacuum by turning on and off by plugging and unplugging? Switch is locked into position and won't move. I have been using it that way. Toni
It's not so much a matter of safety as wearing the motor out quicker. Normally the switch that comes with it smooths the rough edges and surges out of the current. By just plugging and unplugging it to turn on and off, you are exposing it to a surge that will shorten the motor life.
Jun 01, 2017 | Hoover Vacuums
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Where is reset button on Hoover Wind Tunnel vacuum?
Hello my good friend, this cleaner doesn't have a reset button or anything, it resets by itself after cooling down, it takes about 30 minutes to cools down.
Nov 07, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
255 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
