Question about Whirlpool Duet GHW9150P Front Load Washer
Sears He4 has a code F11
I can't find the manual and my machine keeps shutting off with an F11 code. I clear it and restart and it will go a bit more and then F11 code again. Before I start taking days off of work and wait for the sears repairman (I do have a service contract, but they take 2 weeks or more to get someone to the house) I would like to know if it is something stupid I can do myself, so...what is an F 11 code????
  • 8,197 Answers
Here is what the code means.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Good luck and Please Rate FixYa!
Posted on Jan 08, 2009
F11 code appears on the machine
Motor control unit internal failure on a washer. Cannot find an F-11 listed in the dryer service manual
Oct 06, 2012 | Kenmore Elite HE4 Electric Dryer
Keep getting F11 can clear it but it keeps happening
This is usually caused by a loose, corroded, or bad wire. Try this link it should help
F11 Fault code repair
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does a F11 error mean on a Kenmore elite HE3t?
the first thing u must do is ID who makes this machine for sears, sears doesn't manufacture anything, here is the page that shows you how to do that, then with that info i can look up the code difintion. go to link
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears /
Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Thanks for using Fixya.
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
3, Power on
Oct 22, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Error Code E1
Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he4 front load washer
f11 is a communication issue between the 2 control units and wired through and latch assy. most common i find to be is the machine controller, up under the main top of unit, check all your wires!!!!!depending on board can either be 150 , or for the top of line model the part retails for close to 300 and thats just for the part let alone the service and labor
Mar 25, 2008 | Kenmore Elite HE4 Electric Dryer
He4t F0, F11 codes
f11 is a communication error, assuming it was used in one home and now moved to another. i would remove top of unit and check wiring(especially leading to latch assy. that tub was probably banging around quite abit on the move(assuming shipping brackets werent put back in.) def chack all wiring first
Feb 23, 2008 | Kenmore Elite HE4 Electric Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
