Question about Maxtor Hard Drive
I have an old Dell desktop with a burned up Maxtor hard drive Model # 31024H1. Since I need to replace it, I want to know what would be a good choice of an updated HD?
    President:
  • 2,692 Answers
I was just reading an article in a computer magizine compairing 7200  RPM hard drives and their is very little difference between. THe change comes if you want a fast hard drive for gaming with you would not want anyway.   If it is an old Dell it has most likely an ide drive. Make sure to buy the same. Windows Xp only supports 320 Gbytes I beleive. Anything above that is subdivided if used as the  system drive.   Newegg.com  is reasonable and has a good slection of hard drives. Some Walmart have hard drives.
Posted on Jan 08, 2009
Model 34098H4
This FAQ applies to Maxtor model numbers: 31024H1, 31535H2, 32049H2,
33073H3, 34098H4 ... 34098H4, 79,408, 16,383, 16, 63, 40.9, 40,900. ... http://knowledge.seagate.com/articles/en_US/FAQ/195291en?language=en_US - 43k
Follow the link to get full configurations
Feb 01, 2012 | Maxtor Hard Drive
Jumer setting
Depends if you want it to be a slave or master drive?
Nov 04, 2010 | Maxtor DiamondMax VL 40 (31024H1) 10 GB...
I have a maxtor H.D. model # 31024h1 , i cannot find the jumper settings to distinguish between master and slave
Typically, for older MAXTOR drives, put the jumper on the 2 pins closest to where the ribbon-cable connects, to set it to 'MASTER'.
Remove all the jumpers to set it to 'SLAVE'.
Aug 24, 2010 | Computers & Internet
I have a dell optiplex and the hard drive has been removed how do i get new hard driveto run tried to install windowsxp disk failed on restart would not find hard drive HELP
Did you replace the old hard drive with a new one?
Check the connections on the drive itself. When you plugged the new one in, there should have been two cables you plugged into it. 1 small one that goes to the motherboard (called the SATA cable), and one wider one which comes right out of the power supply. If either of these is not plugged into the hard drive, you would get a message that says "could not find drive".
Check your connections and try again. If they're ok, then write back with as much detail as you can provide.
Mar 14, 2010 | Dell OptiPlex GX520 PC Desktop
I need to know how many gb formodel 31024h1
ITs
Maxtor DiamondMaxVL 40 31024H1; 10.2 GB
Jan 09, 2009 | Maxtor Hard Drive
I have an old Dell desktop and want to replace HD
From experience I recommend a Western Digital Hard Disk Drive as I have had far less problems with them then Seagate - As IDE is gradually being phased out I recommend acting soon as the drives will become scarce as they are very cheap and lacking in variety at the moment.
In particular the Western Digital Caviar WD5000AAKB is a good value drive - just over a hundred dollars and features 500GB of space 7200RPM and a 16mb Cache
It seems the best for value at the moment once again I advise you not to delay as vendors are gradually phasing them out.
Hope this information pointed you in the right direction ;)
Blazamane
Jan 08, 2009 | Maxtor Hard Drive
Hard drive problems with Optiplex GX260
You should be able to manually enter the drive perameters into bios. That should let you boot. Or boot it up with a boot disk.
Dec 22, 2008 | Dell OptiPlex GX260 PC Desktop
My maxtor ext. hard drive 120 gb one touch, My dell laptop mod. inspiron 1525 can not read the maxtor. it gives me a code I/O problem. what do I do
try going to system setup! an configering ur 120 hd ! if its an older laptop its bios may not support that big a hard drive! but u can download software for maxtar that will trick it into takeing it!
its a free download ! maxtar.com an the model # an it should do it ! u need to burn the software to a cd or dvd so ur laptop boots up on it! when u download it set it up on ur dvd or cd so it will boot an install ! good luck! merry christmas!
dr fred!!
Dec 17, 2008 | Computers & Internet
Jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Nov 25, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
78 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
