Question about Bertini Bidwell 905 Horizon Standard Stroller
1970 Perego pram wheels need retreading
The pram tires are about 10" in diameter and they are white rubber. Tires are basically ok,but worn and one has a small slash in it. The chrome wheels are in great condition with all spokes firm. I'm refurbishing the pram and this would completely add to the task. Surely somsewhere in the US this could be done.
3 Suggested Answers
  • 70 Answers
SOURCE: Need new wheel
Hi, you need to call the company and ask them for a replacement part. Some companies keep these for several years for a specific model and then there are models that are trial runs, that they only keep parts for 2-3 years past for repairs.
It sounds like yours was made well to start with, so they may have parts for you. I can't find a specific company that would have those. Hopefully you have the books.
Posted on Aug 19, 2008
SOURCE: Wheel replacement for older Peg Perego pram carriage
I have the same problem for a vintage 1860's Pedigree pram. Did you ever get the tires you needed?
Posted on Aug 20, 2010
Can I put 235/60R16 on 2008 chevy uplander
The stock wheel and tire is ;
wheel - 17 x 6.5 inches
TIRE - 225 60 17 702 mm diameter
If you wanted a 235 60 17 that would be ok but the tire diameter is larger by a small margin.
If you are reducing wheel size with 16 inch wheels in order to fit the 16 inch tires mentioned in your question you better make sure that the smaller diameter wheel will clear the brakes front and rear.
For a 235 tire the wheel width will need to be 6.5 inches minimum.
So if you go with ...............
wheel- 16 x 6.5 or 16 x 7 inch
TIRE - 235 60 16(as in your question)- 688 mm diameter
Provided the 16 inch wheel clears the brakes that would be OK but that tire is slightly smaller in diameter than stock but within an acceptable margin.
Make sure whatever tire you select that the tire load rating is not less than the stock tire and not less than the tire load rating stipulated by General Motors for that vehicle..
Feb 28, 2016 | Cars & Trucks
Where can I purchase a replacement tire for a Craftsman 7 1/2 inch band saw ? It is for the lower drive wheel and is app. 10 inches in diameter. It is rubber.
I love using both rubber and urethane tires. My old 14" band saw runs for 15 years with rubber tires on it; I changed it when it started cracking with urethane tires that I got from bandsawparts.com
Jun 09, 2014 | Saws
Tire comes off of wheel
This could be a big wild guess on how the tire comes off on the wheel. But I'll try to help you this thing. I don't know if your bandsaw has adjustment bolt above the upper wheel and below the lower wheel, but in case there is , use these bolts to center the band saw. Well, this could also be blade tension adjustment. Tires should be a very tight fit and a struggle to get on.
Wait, was tired glued on? If not, reglue.
Is that an old tire? If yes, tire must be well worn out and time to invest new ones.
I recommend you to use this time urethane tires rather than rubber tires.
Rubber tires works fine but urethane tires last longer and doesn't need gluing. When you purchase a new tire, make sure that it is a couple of inches smaller than the wheel to stretch the tire. It is a good advice to slightly tilt the top of the drive wheels towards you. I've been purchasing urethane tire with www.bandsawparts.com. Got one from them and still up running. Piece of advise also,Before installing the new tires, you double-check the surfaces of the pulleys to make sure the surfaces are clean and true.
Nov 03, 2012 | Saws
CRAFTSMAN BAND SAW 41815 WHEEL TIRE KEEPS COMING OFF
Check the tires maybe it's worn out. If it is, change the tires. I recommend to glue the tires whether it's urethane or rubber. You can try this site for replacement band tires: www.bandsawparts.com.
Aug 08, 2012 | Craftsman 41815 Wheel Tire
Where can i get a rubber tires for a Peg Perego John Deere Gator HPX 12 Volt Ride on Toy?
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
Oct 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
Steering wheel pulls when turning on a curve and my tires are wearing down because of this
check the air pressure and make sure all tires have the same psi in them. If they do, take it in for a front end alignment or a 4 wheel alignment.
Aug 03, 2010 | 1999 Ford Expedition
How to protect peg perego gaucho ride on jeeps wheels
On my neice's ride on Jeep, I coated the tires in Rubber Undercoating (sold at all Auto part and home improvement stores.) This creates incredibly better traction, looks, and protects the wheels.
Jun 07, 2010 | Peg Perego Gaucho Rock'in
Jul 31, 2009 | Peg Perego Elegante Stroller
Do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Jan 13, 2009 | Peg Perego John Deere Gator HPX Ride on...
1999 chev blazer
transmission computer is receiving a sensor signal indicating that a wheel is losing traction also make sure all tires are same height and diameter ( worn and soft tires could cause weird feedback signals, also worn shocks and springs may allow the wheel(s) to bounce around a lot making it appear as though its got no traction
Nov 18, 2008 | 1999 Chevrolet Blazer
Bertini Bidwell 905 Horizon Standard Stroller Logo
159 people viewed this question
Top Bertini Baby Gear Experts
Joyce Nokleby
Dorel UK
Dorel UK
Tom Chichester
Are you a Bertini Baby Gear Expert? Answer questions, earn points and help others
