Question about Maytag Atlantis MDE6400AY Electric Dryer
Gas Dryer wont start...
I replaced the timer and now there is no power. There is power coming to the timer cause I checked but nothing comes on not even the lamp inside. Its almost like I shorted it out or something. Is there a relay switch or a reset button that I cant see? Please help! I hate the laundromat and I cant afford a new machine after purchasing the timer...
  • Maytag Master
  • 19,396 Answers
Check the door switch, and the fuse, ensure that you rewired the board properly.
You find parts and diagrams by entering the model number here.
Posted on Jan 09, 2009
  • Maytag Master
  • 8,220 Answers
It has to be the door switch because if the fuse blows the dryer will still operate. Did you pay the electric bill amigo?
Posted on Jan 08, 2009
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Lights come on and you can choose your cycle but when you push start i hear a clicking at the top but it wont start
YOU HAVE A BROKE BELT,,, WHEN THE BELT BREAKS IT SHUTS OFF A MICRO SWITCH,, THE TIMER WILL WORK BUT NOTHING HAPPENS
Jan 20, 2011 | Samsung DV448AGE Gas Dryer
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Dryer will not come on
send model number,is it gas or electric?check to make sure you have power where the cord connects to dryer and sent info so i can help you
Feb 24, 2010 | Kenmore Dryers
Dryer won't start, timer makes clicking noise drum sometimes begins to turn but does not come on.
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse, but in this case, the door switch may be the culprit. Check all the areas stated above to cover all suspect issues
Sep 30, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start,
3. Thermal fuse
4. Timer
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Dryer wont come on
check the voltage at the outlet for 220
Feb 16, 2008 | Roper REX4634KQ Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
15 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
