Question about Miele 24 in. G692SC Plus SS Free-standing Dishwasher
Burning smell dishwasher
Can you help? l have a miele that seems to smell of burning alot. l checked that there is no plastic objects wedged under the elements. At the end of the cycle it seems to smell of burning??
5 Suggested Answers
  • 3 Answers
SOURCE: plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Posted on Dec 01, 2008
  • 7 Answers
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Posted on Aug 11, 2009
SOURCE: Whirlpool dishwasher heating element overheating
Same thing just happened to my yesterday on my Kenmore. Expert help needed.
Posted on Dec 04, 2009
SOURCE: Miele G661 Dishwasher heating element
Loosen element-retaining bolt plus clips in dishwash chamber. Upend machine and take base off (held by four crosshead screws). Disconnect spade connectors from end of element and gently tap/push old rubber block through. Element will drop out with retaining rubber.
Posted on Jan 21, 2010
  • 177 Answers
SOURCE: Miele dishwasher not heating
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
0 characters
1 Points
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
A plastic lid melted on the coil, still smells like "melted wax", seems clean, what can I do?
You will probably have to replace the heating coil in the bottom of the dishwasher to get rid of the smell. The coils aren't that expensive and replacing them is an easy job. Hardest part is getting the dishwasher out from under the counter to do it.
Feb 19, 2014 | Whirlpool Dishwashers
Everytime I start my whirpool dishwasher it smells like smoke. If left on for a while a burning smell and steamy smoke come out when I open the door
I would check your heating element to make sure it is clean of plastic on some label that is against it some type of paper or what have you this element heats just like a oven and can burn objects on it or touching it.If you see a spot clean it very gently until that it all is the same color use a scruff pad sponge to use for removal of the spot in question. Remember to rate my solution and give testimonial this is how i earn achievements here on FixYa Thanks in advance.
Apr 25, 2012 | Whirlpool Dishwashers
Our dishwasher started smelling like something is burning, I turned it off straight away, no visible smoke or anything but it hasn't been cleaning very well for a while now. Are these the death throes? Or...
Make sure there isn't any plastic on the heating element. Also check to see if there is any evidence of previously melted plastic. If it smells like plastic burning & you aren't using any heated options, cut the power & call for service.
Mar 27, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I...
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Aug 03, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
My Miele dishwasher does not get the plastic refridgerator items dry
Hello Zipmap0202,
I have never found that plastic dries very well in my Miele dishwasher as well.
Check your rinse aid indicator to see if it is on. Next to the soap door there is a door you can add rinse aid to. There is also a dispensing control knob that allows you to turn the amount of rinse aid dispensed up or down. Try changing the setting and see how that works. I have done this and it has not worked well for me. I find opening the door after the cycle is done (Just cracking) it will dry plastic alot better
Sep 16, 2009 | Miele Optima G2430SCi Stainless Steel...
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
"rubber burning" smell
check to see if the motor is overheating, the motor could
be getting hot causing the smell, if the motor is'nt overheating, then call the local repair man, we live in miami(florida), and we have a dish washer that keeps on rumbling, we are getting it fixed today, the only big big problem is it seems to draw alot of electricity when in operation, so there's my problem
p.s. is your dishwasher also rumbling and drawing electricity?
shawn henks
Nov 26, 2007 | Asko D1716 Built-in Dishwasher
Miele 24 in. G692SC Plus SS Free-standing Dishwasher Logo
184 people viewed this question
Top Miele Dishwashers Experts
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
