Question about Konica Minolta PagePro 1350W Laser Printer
It will not pick pick up the paper.
Sometimes it picks up the first copy and then it says that ther is a paper jam. i open the cover and then it will print one and only one copy.
help.
  • rich_pauluko Jan 08, 2009
    reported on wednesday 1/7/09 that my copier was not picking up my paper sheets. you said to hard boot/unplug the power cord. did that but problem still exists. now what. don't bill me. thank you
  • 2,071 Answers
Just need to clean the roller so its works normal again..
Posted on Jun 11, 2009
    Sergeant:
  • 431 Answers
First cheak the roller in the printer tell me what type of printer it is
Posted on Jan 08, 2009
    President:
  • 2,110 Answers
Use some Q-Tips and alcohol to clean the rubber rollers just above your paper stack - they get dusty and sometimes won't take the next piece of paper.
or
Clean the rubber roller in the middle with Formula 409.
If this doesn't help the roller will need to be replaced:
Part number 4136 3001 01 from 800 972 6705.
  • 4,806 Answers
Hi there
The pick-up roller needs cleaning.
1 Turn off the printer, unplug the power cord, and disconnect all interface cables before cleaning.
2 Grab the front cover grip and open the front cover.
3 Pull the handle of the imaging cartridge toward you, and then
pull out the imaging cartridge
Do not expose the imaging cartridge to light for a long period of time. If the drum cartridge is exposed to light, decreased image quality may result.
4 Wipe the pick-up roller with a soft, dry cloth.
5 Align the imaging cartridge with the guides in the printer, and then insert the cartridge.
6 Press on the front cover grip and close the front cover.
Good luck
    Scholar:
  • 91 Answers
Try cleaning the feed rollers, and fusers or drum cartridges (different than toner or ink), could usually cause the problem
First clean the rollers, then try replacing the drum cartridge, then is that doesn't work, need a new fuser.
Hope this will help you.
  • 56 Answers
There must be a old peice of paper jammed in the back of the unit or the pulling roll has shift out of place seeing that it's all plastic it might not be woth repairing if thats what it is. hope this could help.
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Jan 08, 2009
    • Open the paper jam cover.
  • Remove any paper from the multi-purpose sheet feeder that is not jammed.
  • To loosen the paper, slide the paper width guide to the widest position.
    • Using tweezers, pull out the ripped pieces of paper.
    • Close the paper jam cover
    • Power the unit back ON.
    If you cant find any paper inside the machine .
    Then your roller is not picking the paper properly .You need to clean the roller and try whether you are able to feed the paper properly .
    If your problem still exist you need to replace the roller .
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Hello My machine is Canon iR2016 and i have problem with Paper Jam. I have problem when I copying more then one copy and i got a problem sometimes in the first 10 copys, sometime at 20th copy... Error...
so, first, did you clean the vertical path roller? ( its a axis with two rollers beneath the paper registration sensor )
Second, when you open left cover, and paper guide plastic cover ( black ) there is also sensor flapper, that can be a quite of pain because slow reaction of spring on it. Apply wd40 on its spring and in left corner where he lays into bushing. To check flapper response, manually close the paper guide plastic, the sensor must be in middle position.
Also it can be the problem in paper pick up clutch and it needs to be cleaned or replaced.
But, also the problem can be separation claws in cassette ( metal claws that holds the paper ). From experience, the probably is sensor flapper or pick up clutch the problem.
Hope that helps!
If you need service manual or help, write on emma.servis@gmail.com
Jun 18, 2011 | Canon iR 2016i Black and White Copier
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
Paper jam indicator will not go out...no paper jam found
Hello sir; sometime paper jam right in the begining when it try to pick up the paper from the tray, you not going to see the paper, only thing you can do is pull out the tray reset the paper and push back again, if still jam, then you better clean up the paper pick roller.
Oct 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
Paper jam
Call HP and replace unit under warranty.
Jun 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Nov 06, 2008 | HP DeskJet 3930 InkJet Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Konica Minolta PagePro 1350W Laser Printer Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
