Question about Kenwood KDC-MP235 CD Player
Trying to get to channel 0 on my kenwood mp235 to set up satellite radio, can u help?
    New Friend:
  • 57 Answers
Why zero it is most times 88.7 depeding on where you live then you have to set your sirius unit to that channel in your menu setup good luck
Posted on Jan 10, 2009
I am trying to add Sirius radio on my kenwood DNX572BH MODEL. SIRRUS IS TELLING ME I NEED A RADIO ID number. I cannot locate it since the device is installed
The Radio ID can be found by tuning the radio to channel 0. It is also on the Sirius XM Connect tuner and the packaging for the XM Connect. You can directly tune the radio to a channel by pressing the Up arrow on the control screen. Next look at the bottom left corner of the screen for an icon with 3 rows and columns. Touch this icon. Enter the channel you need and press Enter. See page 68 of the manual for the DNX572BH (page 69 of the PDF). This manual is available from the support page for the Receiver: http://www.kenwood.com/usa/car/navigation_multimedia/dnx572bh/support.html?model=DNX572BH . The direct link to the manual in English is http://manual.kenwood.com/files/IM386_Ref_K_En_01.pdf .
I hope this helps.
Jun 05, 2017 | Kenwood Car Audio & Video
I NEED A MASTER CODE UNLOCKED (KENWOOD KDC-MP235)
Your code number is 5227 (KCAR) As set by Kenwood unless changed by the purchaser. If different then check the link below for excellent tip?
As posted by robotek (Below), Regards.
http://www.fixya.com/support/r538828-security_unlock_code_kenwood_most_models
Jun 08, 2011 | Kenwood KDC-MP235 CD Player
HOW CAN I GET MY BLACKBERRY CURVE 8530 TO SYNC WITH MY KENWOOD KDC-MP235
have you tried searching it in the unit? also make sure there is a setting in the blackberry if it finds it you have to authorise it otherwise it will say it is connected but wont work
Apr 24, 2010 | Kenwood KDC-MP235 CD Player
Need Unlock Code for Kenwood MP235 car stereo
Look for a really small hole in the face plate. Put a tip of a pen into it. Press it in and then it should turn on. If this doesn't work, take it to a place that installs them, they'll help....Usually for free....
Aug 26, 2009 | Kenwood KDC-MP235 CD Player
Lost Sirius Radio:
Goto sirius.com and login to your account. Check the account status and see if its active and enabled.  If it is contact the 800 number for customer service to have the radio reactivated.
Does channel 184 work?
Sep 13, 2008 | Kenwood KDC-MP235 CD Player
Unlock codes
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222" Hope this helps
Jul 06, 2008 | Kenwood KDC-MP235 CD Player
My memmory
did you connect the yellow wire from the radio to a 12 volt power supply that does'nt go out when you turn off the key?
Mar 24, 2008 | Kenwood KDC-MP235 CD Player
My kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Jan 23, 2008 | Car Audio & Video
KENWOOD RADIO
take a pen and press the reset button ...it's a tiny little button next to the button that takes off the faceplate...
Jan 18, 2008 | Kenwood KDC-MP235 CD Player
Kenwood KDC-MP235 CD Player Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
