Question about Chh Chess Board
Warped 20" folding chess board
Now has about a 1/2" gap between the two sides on the hinge edge. How do I fixit? Thanks
Why do my chess piece move oddly
It must a rough side or edge just try to smoothen the base of your chess piece...
sand paper is good
Jun 18, 2016 | Excalibur Phantom Force Electronic Chess...
Lots of water in the boot, mainly accumulated into the spare tyre holding space after rain. Carpet is mostly dry except the edge near the boot opening. The cover board edge nearby is also wet.
There are a couple of obvious reasons for this. If the water is getting in when the car is not moving tghen it is almost certainly the boot lid not beeing corectly positioned or that the rubber seal around the boot is damaged / not fitted corectly. Get a thin piece of card and shut it between boot lid and rubber, if it moves freely along there is a gap (you need to rtry this all the way around the boot). Start inbetween the hinges, the go to 1 side. Repeat for all sides. If it is loose look at bolts on hinges to see if they have moved from original position, you will see marks in the paint around the bolt heads if it has moved. Try loosening the bolts and moving the boot lid until the blots are in the original position. Do 1 at a time and do not remove bolts. If there is no sign of the boot lid being moved you need to inspect the rubber to make sure that it is seated correctly and that it has not perished or been cut anywhere. To stop wheel rusting lift out of whhel well and put some timber in the bottom to lift the wheel out of any water.
Hope this helps. If there is a gap, loosen bolts on one side wshere the hinge is fastened to car and push downon the top of the hinge, this should tighten that side, then repeat for the other hinge. Note if there arte 3 hinges start on one side and move accross in turn.
Jan 06, 2016 | Cars & Trucks
How to tell if your head is warped
To PROPERLY remove the head from the engine it is recommended that the reverse pattern used for head assembly (bolt tightening & torquing) be used.
With a machinists rule (perfect straight edge) visually check length-wise, across and diagonally across the clean surfaces that there is no concave or convex surfaces which are intended to fully mate with the block.
Minor variances can be removed by having the head PROFESSIONALLY resurfaced.
Dec 20, 2015 | Cars & Trucks
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Valve cover gasket leaks
The gasket will need replacing ,but first clean the metal surfaces so they shine ,allso check the surfaces are not warped, use a new steel rule edge to check the engine side a warp will show as a small gap , and the rocker cover can be inspected by placing it on a good pies of glass ,poke around the edge with a bit of fresh clean paper if it slides under a warp is found . a repair will require expert help.
Feb 14, 2010 | 1985 Ford F150
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Frig door does not stay closed
When you say that it will not stay closed, what exactly do you mean? That the door seal does not meet the cabinet, that there is a gap? Is the door warped? Does it appear to be out of line with the hinges on the top and bottom? Is the space around the door when shut and looking at the front pretty much equal all the way around? I mean, when shut, does it appear that there is about 1/4 to 1/2 inch of the cabinet showing all around the door when shut? Has someone swung or leaned or tugged on the door, or closed the door or tried to close the door and something was keeping either the top or the bottom pushed out? There are adjustments on the hinges, at the attachment points to the cabinet and to the door itself. You may be able to adjust the hinge plates in or out and up and down to make the door seal better. And the box should be about half a bubble out of level, front to back, or with a slight angle front to back, in order to help the weight of the door seal to the cabinet of the refrigerator. If the door is warped, you may be able to determine which way it is bent, out at top, out a bottom, side to side, ect. and take it off the hinges and gently attempt to straighten this bend. If you are careful, and can determine there is warping at the top or bottom, you may be able to "straighten" the door while attached to the hinges. Gentle pressure is the procedure, GENTLE, GENTLE. Don't get the BIG HAMMER out and go to banging away. Just a push up here, and a tug down there, and you may be able to cure this fairly easy. You must first determine which way the door is warped, and then move it back the other way. It should seal the gasket to the cabinet, not so much attach the door to the cabinet edges, but a firm seal that takes a tug to open. And no air gaps. Are the products inside the refrigerator "sweating". This is the drawing of warmer room air into the cabinet and condensation forming. The door needs to seal in order to keep the cold air in, and the outside air OUT. I an extreme warping, you may have to replace the door, or use bungee straps to keep it shut. which will be a pain, removing those every time you need in it. I would try and determine where it may be bent or warped, and gently bend it back the other way a little at a time till I have the seal connecting all the way around. Once there, QUIT. No more bending. When the seal connects all the way around, you are finished. Problem solved. I wish you luck and hope that you can solve this fairly easy. Remember, be Gentle. It will warp easily. And no hanging on the door!
Sep 26, 2009 | Sub-Zero 680 / F
The freezer door on our GE side by side fridge does not shut tightly in the center of the door causing a frost and ice build-up on the outside of the door, ( in the inside edges. We have been told that...
There are ways to adjust the hinges, and loosening the screws on the plastic door liner will allow you to "warp" to door a little bit in an effort to get it to line up flat and square to the opening. Sometimes the gasket gets folded up on the hinge side and won't let the door close properly. If you try these adjustments and the door just can't be fitted nicely, you have a serious ploblem. Use something straight to see if the cabinet is warped or if it is the door that is warped.
Jul 23, 2008 | GE Refrigerators
Chh Chess Board Logo
59 people viewed this question
Top Chh Games Experts
Lesley Cameron
Lesley Cameron
Are you a Chh Game Expert? Answer questions, earn points and help others
