Question about Zyxel Prestige 2000W
NOT registered is the info banner i get all the time i try to connect to a wlan
Hi Am compltely new to this product.The thing is am trying to Create a SIP account and trying myself to connect to Wlan. And i followed the Settings which i got from Zyxel2000w.pdf The Wlan is workin fine (Connected other devices to same Wlan) Plz help me out to proceed further.
3 Suggested Answers
  • 7 Answers
SOURCE: nortel wlan handset 2210
that is done through CS 1000E switch.
YOU WANT COMMANDS PLS LET ME KNOW.
Posted on Feb 13, 2008
SOURCE: hi, I can´t activate the WLAN.
i need to joint wireless conecat
Posted on Jan 27, 2011
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
May 10, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
My N95 connects to linksys with no problem...But my Nokia e90 gives error "Unable yo connect.WLAN not found."
Hi wasiullahkha,
I see that you connect your Mobile phones to your Router, but you ge an error using your Nokia e90.
> try to check the wireless setting for the Router.
>this is possible that the Router is set to provide wireless only to deivces that are registered on the Linksys settings MAC address.
>try and check the setting in the Linksys Router possibly MAC Address Filtering check if it is enabled if it is then that will be the cause, you will just need to get the MAC Address of your E90 phone and register in the Router settings for the wireless to work and be detected by the phone.
Or check to see if he router is set to be discoverable or not by other devices , if it is not set to be discovered or the SSID is hidden then you cn manually input that info on your Mobile phone.
these are the only options in a Router that can cause devices not to detect the router signal right away.
I hope that his helps.
Have a nice day,
mvincentc
May 06, 2011 | Linksys Wireless-G WRT54G Router
Hi, I've been trying to register our new nuvi 255w
Hi!
BEFORE you try to log in to their website, you MUST create an account.
Here's the link to that page:
https://my.garmin.com/mygarmin/registrationGettingStarted.htm
Under My Garmin sign in, there's a "Don't have an account? Create one"
Put your full name, email addy, a username, password (6 character minimum) and confirm password in the appropriate fields. THEN you'll be in business to register your product!
Hope this is helpful to you.
Good Luck!
Jan 24, 2011 | Garmin nuvi 255W GPS Receiver
I have a new psp 3000. I can't get internet access. It finds the SSID, good reception=75%. WLAN on, but its saying "a connection error occurred. Connection point could not be established. Check...
Hi stagedoorste,
You may notice that sometimes connecting your PSP to your network seems like a hard thing to do. But if you're aware of the basic configuration you can say that it's not a complicated thing. If your experiencing hard time connecting to the internet please make sure to check on the error. Based on what you have mentioned it says that you need to check the security setting. You may try following the steps below for the basic configuration on how to connect your PSP to your router.
1. First step is to make sure to turn on your PSP as well as the wireless/WLAN switch. 2. Then Navigate to " Network Setting". 3. Select "Infrastructure Mode". 4. Now Select "New Connection" and Name this connection as you deem appropriate. 5. Navigate to "WLAN Settings" Select "Scan". 6. Your router should now be listed. 7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None" 8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA. 9. Then navigate to "Address Settings". Select "Easy" 10. Go to "Setting List". Verify that your settings are correct. 11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X. 12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection and using your PSP you can now browse the net.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Slim...
We are trying to register our 255w Garmin product, however, it seems like we are going in circles. It won't recognize our password, then it won't recognize our username, then it says our password has...
I would first clear your cookies in your web browser.....
Try to connect again
All Garmin GPS systems are Registered wih Garmin to unlock the map data, so every owner has to call to get their gps' working.
If you say you Registered your product you can give them your Serial number and personal info so they can help you out and delete the account it was under.
So if it didn't work the first time and they have no records of it, all you would need to do now is to Re-Register
www.Garmin.com
Oct 31, 2010 | Garmin nuvi 255W GPS Receiver
I am unable to register my psp, i cant hook up to wifi to do it, is there another way to do it?
Hi deathtoner,
Based on your concern, I suggest trying the following steps:
1. Turn your PSP on.
2. Make sure that your WLAN switch is turned on.
3. Perform a factory reset.
--> To do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step.
However, you may need to reset your wallpapers. Set your name, date, time, etc...
4. Power down your PSP then wait 10 seconds, then power it on.
5. Navigate to "Network Settings".
a. Select "Infrastructure Mode"
b. Select "New Connection" Name this connection as you deem appropriate.
c. Navigate to "WLAN Settings" Select "Scan".
d. Your router should now be listed.
e. Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None"
f. If you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA..
g. Navigate to "Address Settings". Select "Easy"
h. Navigate to "Setting List". Verify that your settings are correct.
i. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
j. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
Hope it helps,
Thank you for using Fixya.
Jan 17, 2010 | Sony PSP-3000 Silver Console
Failed to register! error-code: 408, msg: 'Request Timeout'
Errors / Solutions (Error 408, 401, 503 / Not Connecting / Failed to Register / Audio Problems):
You can try using port 8891 or 80 setting if 5060 port is blocked
Simply change the sip.tpad.com settings in Xlite to
sip.tpad.com:8891
or
sip.tpad.com:80
Use our STUN Settings, simply use the info on this link (stun.fwdnet.net:3478)
http://forum.tpad.com/viewtopic.php?t=617
http://www.youtube.com/watch?v=ugHwkl--zhQ
Use these other Free Softphones with Tpad:
http://forum.tpad.com/viewtopic.php?t=623
http://forum.tpad.com/viewtopic.php?t=864
http://forum.tpad.com/viewtopic.php?t=657
http://forum.tpad.com/viewtopic.php?t=456
May 02, 2009 | Computers & Internet
I'm trying to register my new vizio television
Just go to www.vizio.com. On the choices at the top pick "register". It's that easy. I just did it.
Feb 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Zyxel Prestige 2000W Logo
52 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
