Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Disk read errors
By St1g on May 31, 2007
I turned my xbox360 on last night to continue where I left off with Tiger Woods 07, the game started alright but as soon as I pressed start the entire screen went black and in white writing "the disk is damaged or dirty" message appeared. On inspection the disc was neither damaged or dirty.
I decided to try another game , long story short my 360 gives the same message for every one of my games , I have had my 360 since launch day and have not had any problems so far.
I tried to remedy this by cleaning with one of those laser cleaner disk things only to read this morning NOT to do this (doh) Being a brit shipping my 360 stateside for repair is not really an option due to my impatience
I can't be without one so was gonna buy another on the way home from work,but whilst browsing for help stumbled across this site and thought I'd see what you peeps think. Any ideas?
Same Problem
Mar 16, 2008
-   Don't use that guide - it has you putting erasers into your xbox -ruining it for good!
I've fixed hundreds of xbox 360s with the 3 red light error. I did it with a real xbox 360 repair guide.
Don't use a repair guide that uses erasers or towels - that will ruin your xbox 360 for good. If you get one of these guides, don't use it, or ask for your money back - you'll need it once your xbox is ruined.
Only use a real repair guide with real repairs from 3RedLightFix.com-   Guest
Mar 16, 2008
-   disk read errors on non-scratched disks-   patrick463
Best Solution
posted on Aug 23, 2007
Very Helpful)
philipp
Rank: Wiz
Rating: 83%, 300 votes
Try to use cd rom lens head cleaner, the one with the small brush at the middle of the disk, never use cleaner using liquid solution. the best cleaning method is to open the cd and clean manually the laser lens using a cotton buds, the lens are so delicate so don't apply too much force. you can easily locate the lens in the cd case, it is a round bluish lens. cd rom cleaner works best when your unit is clean!! Huhh? Run it once a day, regularly, its like sweeping the floor of your house before you work for that day. Cd rom cleaning depends on playing back the No 1 and jumps to no 3 tracks, cleaning takes place on track 2 of the disc, you cannot clean if you cannot play the unit.. get that?
Was this helpful?
Yes
No
Solution #2
posted on Jun 23, 2007
Helpful)
RFro
Rank: Guide
Rating: 95%, 61 votes
Disk read errors on the XBox 360 are usually related to the overheating issues. I had disk read errors on my Xbox360 until I bought a 3rd party cooler.
The fact that you get read errors non-stop may mean your system has suffered heat damage and needs to be sent into Microsoft for repairs/replacement.
Was this helpful?
Yes
No
Solution #3
Not Rated)
PrimoDread
Rank: Guide
Rating: 88%, 21 votes
If your xbox says (unplayable disc) and no disc plays including dvd, mp3, etc. then you do have a fatal hardware flaw in the disc drive. This should be covered under the new 3 year extended warranty. This problem is rumored to be caused by two things,1 cheap disc drives, 2 live update which was trying to ban modded 360s for xbox live friendly fired on alot of innocent disc drives with bad firmware.....but this should be covered, give em a call
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
unit not reading disc seems reader is sticking and have old unit displays a e74 error code
Answer
Can't restart missions on Spiderman 3 game for Xbox 360. What do I do ?
Answer
I Went to Buff out 2 of mi Xbox 360 games And i find out that none of them work smh What do i do ?
Answer
i have connect my xbox 360 to my modem using an ethernet wire but it still won't connect. Something... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
