Question about Maytag MDE2600 Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
I have a Frigidaire dryer. The back and top of dryer get extremely hot. The clothes take an excessive amount of time to dry. A load which normally took 50-60 minutes to dry takes about 2 hours.
  • Anonymous Mar 12, 2014
    It suddenly takes several hours to dry a load whereas it only took 1 hour before
  • Anonymous Mar 22, 2014
    Dryer gets very hot to the touch clothes get ruined
  • 126 Answers
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Posted on Jan 08, 2009
Dryer vent has been checked, ok. the element is hot because the the top of dryer extremly hot.Still taking a long time to dry the cloths ?
Could be the thermostat is switching it off . Only the size of a large battery normally situated on the heater unit somewhere .
Sep 05, 2017 | Dryers
Why is my Frigidaire dryer model #FER86600ES0 getting extremely hot on the top and back?
Good afternoon friend, thanks for the post!
I see from your post that your Frigidaire dryer is getting extremely hot on the top and back. Have you checked to make sure that it is getting proper ventilation? I would verify nothing is blocking your dryer from ventilating which could be causing the appliance to heat up. If it continues to heat up I would reach out to a technician to come diagnose and repair your dryer. I hope this is helpful. -Matt
Jul 31, 2014 | Frigidaire Dryers
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
My Frigidaire dryer makes a loud humming noise and the top and back get very hot to the touch.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
May 20, 2012 | Frigidaire FGR341AC Electric Dryer
We have a gas dryer purchased in 1996, Model #CDG800W. The dryer has started to make a strange grinding sound when we're drying clothes. Any suggestions?
Most likely a bad blower wheel. Over time the hub gets hot, melts, wobbles out, and start to rub the blower housing. The wheel slips and makes it take a long time to dry the clothes. This causes the filter to warp and the top to get extremely hot.fdd151b.jpg513b315.jpga1f312f.jpg77fbb60.jpg
I have posted more repair photos here
Nov 01, 2010 | Crosley Dryers
Cloths take to long to dry. the back is hot so it is heating.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 26, 2010 | Frigidaire FEQ332E Electric Dryer
Takes long time to dry clothes
clean out hose or if it's to long cut to fit with no slack thank you for useing fixya rate me
Mar 30, 2009 | Kenmore 73952 Gas Dryer
Dryer gets hot to the touch
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of...
okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Apr 03, 2008 | Dryers
Maytag MDE2600 Electric Dryer Logo
262 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
